Using Gauss's Law to determine an electric field
Gauss's Law is discussed as a method to determine electric fields, with the equation φ = ∫E dA = Q/ε₀ being central to the conversation. The user has simplified the equation to E = Q/(2πrε₀) but is uncertain about its correctness and application. Assistance is offered to study the basics of Gauss's Law and its derivation. The importance of understanding the applications of Gauss's Law is emphasized for solving the homework problem. Further guidance is promised once the user gains a clearer understanding of the concepts.
loba333
{\phi} = \int E dA = \frac{QL}{\epsilon_0}
I'm aware of the definition of Gauss's law of electrostatics (however evidently I'm not very good at applying it), but I can't seem to fully answer the rest of the question.
An example in my book states the equation above and I've managed to simplify it to this state:
E = \frac{Q}{2\pi r \epsilon_0}
But I was wondering if this is the right route to go down, and if this is a correct equation, how I could use it to solve this problem.
Thanks in advance for any help, will be checking back sporadically.
Looks good. You found the answer to (ii) in part (b). Do you know what the answer to (i) is?
answer to (i) (a) was given in your book or you know how to derive it?
Not quite sure how to derive it and I didn't even know I'd done the answer to part (ii) :X
Ok .. so you need to study applications of guass law
go here: http://hyperphysics.phy-astr.gsu.edu/hbase/electric/gaulaw.html"
just study basics of usage of guass law ... and yes also please your questions's derivation too.
and come back on this forum when you have understood it ...
we'll help you find answer to rest of questions.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
