What Are the Correct Answers to These Physics and Optics Problems?
  • Thread starter Thread starter indiansfan4life
The discussion revolves around solving various physics and optics problems, including topics like wavelength, index of refraction, intensity, and illuminance. The user provides answers to several questions but expresses uncertainty about some calculations, particularly regarding intensity and illuminance. They demonstrate attempts at solving problems by showing their work, especially for questions involving wavelength and refraction angles. Key calculations include deriving a wavelength of 0.335 m and an index of refraction of 1.22. Overall, the user seeks clarification and assistance to improve their understanding of the concepts involved.
indiansfan4life
analysis:
10. the picture that we see in a mirror is called the
my answer=image
11. the actual object that makes a picture that we see on a mirror is called the
my answer=specular
-problems- show your work
15. What is the wavelength of a wave with a frequency of 100.4 MHz?
16. A substance allows light to travel through it with a velocity of 2.45 x10^8 m/s. What is the substances index of refraction?
17. What is the intensity of a light that has a lumnious flux of 750 lumens?
18. What is the illuminance provided by a light with a luminous flux of 1120 lm when it is 2.3 meters away?
19. What would the angle of refraction be if a light ray starts in a diamond and goes into the air it has an angle of incidence of 9 degrees.
20. What is the critical angle of light going from quartz to air?
22. What is the illuminance of a light when it is 4.6 m away from a light with an intensity of 78 candle power?
thanks for any help I don't know what I am doing
Here's my answers:
#15: .335 m
#16: 1.22
#17: I was not sure how to do this one.
#18: I was also not sure how to do this one.
#19: 24.44 degrees
#20: 40.37 degrees
#22. 3.6
Show that you've tried. Providing the answers is not enough.
#15: 100.4 x 10^6
3 x 10^8
divide c by f
=.335
#16: 2.45 x 10^8/ 3x 10^8 =1.22
#17: Like I said, I don't know what to do
#18: Dunno what to do
#19: 2.417(SIN)Q2=1(SIN)90
=24.44 degrees
#20: I just plugged it in and got 40.37 degrees for this one
SIN X= 1/1.544 then I did some other work to get the angle
#22: I wasn't really sure with this one but I used the illuminance equation to solve. I doubt it's right.
