What are the steps for reducing sound intensity by 20 decibels?
To reduce sound intensity by 20 decibels, the man must move from 3 meters to 30 meters away from the siren. The intensity level is calculated using the formula 20 = 10 log(I/I0), which indicates that a tenfold increase in distance results in a 20 dB decrease in intensity. The inverse square law applies, confirming that sound intensity diminishes with distance. The discussion highlights confusion around using logarithmic equations for sound intensity calculations. Ultimately, the correct distance for a 20 dB reduction is established as 30 meters.
ongobongo
A man stands 3m from a siren. How far does he have to move to reduce the intensity level by 20 decibels?
Intensity level = 10log(I/Io)
the inverse square law
i know the answer is 30m because 10 times the distance drops the intensity by 20 dB although i don't understand how to use the equations to answer such a question, what are the steps involved
welcome to pf!
hi ongobongo! welcome to pf! :smile:
start with 20 = 10 log(I/I0) :wink:
hi thanks for the hint but honestly i can't make heads or tails of the equation
simplify 20 = 10 log(I/I0)
I=10*10
√100 = 10
10*3 = 30m
ongobongo said:
I=10*10
√100 = 10
10*3 = 30m
yeees … i think you've got it, but i can't really tell :redface:
shouldn't your proof have an I0 in it somewhere? and some reference to logs?
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
