What is the coefficient of static fraction for the book?
To find the coefficient of static friction for a 1.8 kg book that requires 2.25 N to start sliding, the normal force (Fn) must first be determined. The force exerted by the book on the table is calculated to be 17.64 N. The maximum static friction force (Ff) is equal to the applied force of 2.25 N. Using the formula Ff = μN, the coefficient of static friction (μ) can be calculated by dividing the friction force by the normal force. Understanding that the net force is zero when the book just begins to slide is crucial for solving this problem.
Raiden9
I really don't know where to find the acceleration of the object in this question.
When you push a 1.8 kg book resting on a tabletop, it takes 2.25 N to start the book sliding. Hwat is the coefficient of static fraction?
Any help would be greatly appreciated, I have already done the force diagram and equations, found Fg and Fn, I just don't know how you would find the acceleration of the object.
Thank You!
F_\mu = \mu N
Fmu being the force caused by friction, mu the coefficent of friction and N the force the surface exerts on the object.
Using Newton's III, in your problem, can you figure out the force exerted on the book by the table?
I found out that it was 931N. But then where would I go with that? Because I would need to find the Ff then divide that by 931N.
Thank You!
How did you get 931 N? That is a big force for a book with a mass of only 1,8kg:
F = ma <=> a = F/m = 931 N / 1,8 kg = 517 m/s^2.
If by Ff you mean Fmu, the force caused by friction, you already know its maximum magnitude.
I was looking at the problem! I am sorry! I got 17.64 for the Force of book (Fn) on the table. Now, would why I take that since if I got that answer I would take Fn=17.64/mass=1.8 equals the acceleration. Wouldn't I need to find the Ff first then take that and divide it by the mass?
Hey there!
May I know whether you want to find the acceleration of the book when it begins to slide, or the coefficient of static friction in this question?
Don't think that you need to know the acceleration in order to find the force! For one thing, Newton's 2nd law says that the net force equals ma. In this case, the net force is zero--it just barely begins to slide. So that won't help you.
Note that you are given the friction force. Use the formula that Päällikkö gave for relating the maximum static friction to the normal force.
