What is the conservation of energy problem involving h and v?
The discussion revolves around a conservation of energy problem involving a bow and arrow, focusing on the relationship between potential energy in the spring and the gravitational potential energy of the arrow. Participants express confusion about the relevant equations, particularly how to incorporate the spring constant and the energy stored in the spring. There is a suggestion to use Hooke's Law and to calculate the average force exerted on the arrow during its release. The conversation highlights the need to relate the work done on the arrow to its maximum height and velocity. Overall, the participants seek clarity on how to approach the problem and apply the conservation of energy principles effectively.
Karhitect
i attached the problem since its easier.
im not sure. i know the equation for h has to be included. but I am not sure what other equations must be used.
I honestly don't know how to begin. Any kind of help would be greatly appreciated!
i didnt think i had to use the potential spring energy equation because i need to find the velocity for when it comes back down...im really bad at this lol sorry
The terminology in the problem statement is confusing. When the problem refers to "strength", what it is really referring to is stiffness or spring constant. The term strength is usually reserved for when something breaks. You also apparently need to assume that the force the bow string exerts on the arrow is directly proportional to the draw displacement, such that when the draw displacement is zero, the force is zero, and when the displacement is d, the force is kd. So..., during the time that the arrow is in contact with the bow, what is the average force exerted on it by the bow? How much work is done on the arrow by the bow during the contact period? What does this translate into in terms of gravitational potential energy when the arrow reaches its maximum height. What is the upward velocity of the arrow when it reaches its maximum height?
would the equation be 1/2mv2=mgh
then replace h with the equation for h and isolate v??
im just not understanding this problem.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
