How Do You Calculate Total Displacement in Multi-Stage Motion Problems?
  • Thread starter Thread starter TheGeek
    Displacement
To calculate total displacement in multi-stage motion problems, first determine the displacement for each segment using kinematic equations. In this case, the particle's displacement for the first segment (A) is 100 m, and for the second segment (B), it is 20 m. The final velocity from segment A is needed to solve for the displacement in segment C. The relationship between the segments is crucial, as the final results from one segment serve as inputs for the next. Understanding this chaining of calculations is essential for finding the total displacement after 30 seconds.
TheGeek
A). A particle starts from rest and moves for 10 s with an acceleration of 2 m/s^2.
B). For the next 20 s, the acceleration of the particle is -1.2 m/s^2.
C). What is the displacement of the particle at the end of the 30 s.
2. Homework Equations
Kinematic equations
hhqf3mW
I was able to find the Displacement of A = 100 m and B = 20 m
However I can't find the Displacement of C because I don't know how to find the last acceleration or V-final
Thank You.
Draw a graph of the motion and from there you can see how to get the answer.
From part B you can get the velocity needed for part C. Remember vf=at+v0 where v0 is from part A
TheGeek said:
B = 20 m
How did you get that?
Did you mean "From part A you can get the velocity needed for part B"?
Yes, it's a chained problem right? So the results of A with ##v_{Afinal}## and ##d_{Afinal}## are inputs to part B. and the results of ##v_{Bfinal}## and ##d_{Bfinal}## are inputs to C.
