What is the magnitude of the electric field (rod)?
The problem involves calculating the electric field generated by two uniformly charged glass rods positioned parallel to each other. The rods are specified to be of finite length and are separated by a certain distance. The context suggests a focus on the electric field along a bisector line between the rods.
  • Participants discuss the validity of treating the rods as infinitely long versus finite length, questioning how this assumption affects the calculation of the electric field. There is mention of confusion regarding the setup of the problem and the appropriate equations to use.
The discussion is active, with participants exploring different interpretations of the problem setup. Some guidance has been offered regarding the implications of rod length on the calculations, and there is a shared uncertainty about the correct approach to take.
Participants note the specific lengths of the rods and express confusion about how to apply the relevant equations for finite versus infinite rod scenarios. There is an acknowledgment of the need for calculus in addressing the problem, suggesting a potential complexity in the solution approach.
sunnnystrong
Two thin glass rods are placed side by side 4.70 cm apart as shown in the diagram below. They are each 11.3 cm long and are uniformly charged to +10.4 nC .
Answer the questions below regarding the electric field along a line which is drawn through the middle of the two glass rods (labeled Bisector in the diagram).
(Figure 1)
*See attached file for relevant equations*
Length = 0.113 m
λ = 9.20×10^−8 C/m
Eo = 8.85*10^-12
r1 = 0.037m
r2 = 0.01m
Using the attached equation... I got -1.21*10^5 N/C ... the magnitude of the field is 1.21*10^5 N/C
I know this is wrong but I am confused as to why?
Are you allowed to treat the rods as infinitely long?
Honestly, I have no idea. I am confused about how to set this problem up but found this equation in my book.
I would think not though as they gave you the length of the rods ?
I tend to agree with you, that they do not want you to approximate the rods as infinitely long. But the formula for E that you are using is for an infinitely long rod.
Do you have an idea of how to handle the case of a rod of finite length? Are you using calculus in your course?
  • · Replies 23 ·
  • · Replies 16 ·
