What is wrong with this answer?
  • Thread starter Thread starter seven0sav
The discussion clarifies the distinction between mass and weight, emphasizing that mass is constant while weight varies with gravity. It highlights a calculation error where weight was incorrectly stated in kilograms instead of Newtons, which is necessary for accurate force representation. The correct formula for determining mass from weight is provided, demonstrating the need for proper units in calculations. Rounding errors and unit omissions are identified as key issues in the original answer. Accurate unit usage is essential for clarity and correctness in scientific discussions.
seven0sav
Everything seems to make sense to me, but I know the answer is wrong..
"Actually, mass and weight are not the same thing. Mass is how much of something there is - which does not change throughout the universe (mass = density * volume). Weight is a force, which is constantly changing throughout the universe depending on the acceleration of gravity (weight = mass * acceleration of gravity).
You can work out a persons mass simple by dividing their weight by 9.806 (Earth's acceleration of gravity).
For example, if your weight = 80 kilograms, then your mass would be 8.15 kilograms. Because -- 80 kilograms / 9.806 = 8.15 kilograms"
You are absolutely right about all the descriptions. Why do you say you are wrong??
The only errors I see is a possible rounding error, and a unit error.
you said "weight = 80 kilograms" this is nonsensical. You yourself said weight is a force (and it is) so you would need "weight = 80 Newtons" or some other unit of force.
Then when you divide by acceleration you would have "8.16 kilograms"
Always put correct units on all numbers in calculations, you forgot units on your acceleration as well.
It should look like:
80 Newtons / 9.8 meters per second squared = 8.16 kilograms.
