What length of steel is above the surface?
The problem involves calculating the length of a steel cylinder above the surface of mercury. Given a 10-cm-diameter and 80-cm-tall steel cylinder with a density of 7900 kg/m³, the solution requires applying the principles of buoyancy and density. The correct calculation shows that 23 cm of the cylinder is submerged, leaving 57 cm above the mercury surface. The final answer is derived by converting the submerged height back to centimeters and subtracting from the total height.
  • Understanding of buoyancy principles and Archimedes' principle
  • Knowledge of density calculations and units (kg/m³)
  • Familiarity with the volume formula for cylinders (Volume = Pi * r² * h)
  • Ability to perform unit conversions accurately
  • Study buoyancy and its applications in fluid mechanics
  • Learn about density and specific gravity calculations in different fluids
  • Explore the implications of Archimedes' principle in real-world scenarios
  • Practice problems involving submerged objects and buoyant forces
Students in physics or engineering courses, educators teaching fluid mechanics, and professionals involved in material science or structural engineering.
UMDstudent
[SOLVED] What length of steel is above the surface?
A 10-cm-diameter, 80.0 -tall steel cylinder (density of steel 7900) floats in mercury. The axis of the cylinder is perpendicular to the surface.
Free body Diagram
Density = Mass / Volume
Buoyant Force = mass*gravity (Free Body Diagram)
Volume of a cylinder = Pi * r^2 * h
Given : Radius = .05m | Height = .4m | Density of Steel = 7900 kg/m^3 | Density of Mercury 13570 kg/m^3 |
Unknowns : Mass of steel pipe ? | height above the mercury? |
First thing i did was draw a Free Body Diagram where i calculated that the Buoyant Force was equal to the mass * gravity of the pipe/rod:
Fb = mg : rho*pi*r^2*h = m (both gravity's cancel ) I can transform this formula into :
Height = Mass / rho * Pi * R^2
How do we determine mass? We know that Density = Mass/ Volume. So we get :
Mass = Volume * Density = (Pi *r^2*h)*Density = pi*.05^2*.4*7900 = 24.8 kg
Now, we plug that into the above equation (Height = Mass / rho * Pi * R^2 ) :
Height = 24.8kg/13570 * pi*.05^2 = .23 centimeters. This should be the right answer but according to mastering Physics, this is incorrect. It seem logical, where did i go wrong?
-SHANE
nvm, I figured this out. I needed to just convert that answer back to centimeters and then subtract that *23 centimeters from the original 80.
Thanks.
nvm, I figured this out. I needed to just convert that answer back to centimeters and then subtract that *23 centimeters from the original 80.Thanks.
  • · Replies 63 ·
  • · Replies 18 ·
  • · Replies 16 ·
  • · Replies 36 ·
