What percentage of a boat is above water when it has a density of 0.75 g/cc?
  • Thread starter Thread starter kazimmerman
    Buoyancy
The problem involves determining the percentage of a boat that is above water when the boat has a density of 0.75 g/cc. The context is buoyancy and the principles governing floating objects in fluids.
  • Participants discuss the relationship between the density of the boat and the density of water, questioning whether the difference in density directly correlates to the percentage of the boat above water. Some suggest using buoyancy principles and equations related to forces acting on the submerged portion of the boat.
Several participants have provided insights into the buoyancy forces and the relationship between the weight of the displaced water and the weight of the boat. There is a general agreement on the conceptual approach, but no explicit consensus on the final procedure or calculations has been reached.
Participants note the density of water as 1 g/cc and express uncertainty about the exact procedure for solving the problem, indicating a potential gap in understanding buoyancy equations.
kazimmerman
A boat with a density of 0.75 g/cc is floating in water. What percentage of the boat is floating above the surface of the water?
I don't know any general formulas for buoyancy. I was hoping someone here could provide one.
I understand that the density of water is 1 g/cc, so is it really as easy as understanding 1-0.75, or is that simply a coincidence. I know the answer is 25% and expected a rather low number due to the rather low density, but what is the exact procedure for solving this problem?
Every cc of boat in the water receives 1cc weight of water worth of pushing up.
So 1g/cc of flotation, if the boat weights 0.75g/cc then you get 0.25g/cc of overall flotation.
That pretty much does it.
It would be clearer if you started with Fg = Fb
where the buoyancy force Fb = (mass of water displaced)*g.
The mass displaced is the density of water times the volume of water displaced.
Draw a block partly submerged in the water, and use that at as a Free Body Diagram. Put the forces on it, a buoyant force and a weight force, and then set up the statics problem. Then work it out as Delphi51 says.
Thanks everybody. That was my line of thinking, but I wanted to be sure I wasn't mistaken.
As Archimedes is supposed to have said in his bath:
"Eureka"
  • · Replies 18 ·
