What Torque Is Required to Raise a Water Bucket from a Well?
  • Thread starter Thread starter OierL
    Apply Torque
To determine the torque required to raise a 20 kg water bucket from a well using a crank attached to a 50 kg cylinder, the relevant equations of motion and torque must be applied. The torque calculated for raising the bucket at a constant speed is approximately 24.5 N.m, which aligns with one of the provided options. The mass of the cylinder is not necessary for this calculation since the bucket is being raised at a constant speed, indicating no acceleration. The discussion highlights that the cylinder's mass may have been included to complicate the problem. Ultimately, the correct torque value is essential for selecting the appropriate answer from the given choices.
OierL
Water is drawn from a well in a bucket tied to the end of a rope whose other end wraps around a cylinder of mass 50 kg and diameter 25 cm. As you turn this cylinder with a crank, the rope raises the bucket. If the mass of a bucket of water is 20 kg, what torque must you apply to the crank to raise the bucket of water at a constant speed?
Solution:
a. 2.5 N.m
b. 24 N.m
c. 80 N.m
d. 2400 N.m
e. 49 N.m
I don't know which one is the correct solution and why they give me the data of the weight of the cylinder.
∑F=m*a
∑M=F*r and ∑M=I*α
If we raise the bucket at a constant speed, ∑M=0
-m(bucket)*g + T=m*α*r=0 (constant speed) ⇒ T=m*g
∑M= (-T*R) + (τ)=0 (Being τ the torque I apply) ⇒ -(m*g*R) + τ=0 ⇒ τ= 20 * 9,8 * (0,25/2)
τ=24,5N*m
Your answer looks fine. The mass of the cylinder will be needed if the bucket has a given acceleration different from zero.
Your solution looks good to me. The mass of the cylinder was just to throw you off.
Ok thank you! Now I'll have to think which of the solutions choose, since my result is different from the others hahaha.
The choice should be clear.
That should not be too hard. Note that the numbers are given to two significant figures.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
