Where are these directions coming from? (Electric Field)
The discussion revolves around the electric field generated by two infinite sheets of electric charge, one positively charged and the other negatively charged, which intersect at right angles. The original poster seeks clarification on the directional components of the electric field vectors derived from these sheets.
  • Participants discuss the nature of electric fields produced by charged planes, questioning how the directions of the electric field vectors are determined. Some express uncertainty about the underlying principles of electric fields from infinite sheets and the vector addition involved.
The conversation is ongoing, with participants exploring various interpretations of the electric field directions. Some have provided insights into vector addition and the geometry involved, while others suggest reviewing foundational concepts related to electric fields.
There appears to be a lack of familiarity with the basic principles of electric fields from uniformly charged planes, which is affecting the understanding of the problem. Participants are encouraged to seek additional resources to clarify these concepts.
emhelp100
Two uniform infinite sheets of electric charge, one with charge density +o and the other with -o, intersect at right angles. Find and sketch the electric field [itex]\vec{E}[/itex]
[itex]\vec{E} = \frac{\sigma}{2e_0}[/itex]
Given solution:
[/B]
Numbered counterclockwise starting from [itex]\hat{x}[/itex]
Can someone explain where the directions are coming from?
Why is it [itex](\frac{\hat{x}-\hat{y}}{\sqrt{2}} + \frac{-\hat{x}-\hat{y}}{\sqrt{2}})[/itex] for 1. and etc?
I don't know about electric fields, but the expressions are the sum of two vectors perpendicular to the sheets.
I guess the field due to a plane must be perpendicular to the plane, so the field between two planes is the sum of two fields.
Are you familiar with what the electric field from a single infinite uniformly charged plane is?
no
Why is the red line +x-y?
EDIT: Ooops! Ignore this line! (I take it you mean the left hand arrow: it is perpendicular to the + plane and pointing away from it.)
You get the red vectors by adding two black vectors.
eg. the down left red arrow is what you get if you follow the black down arrow (-y) then the black left arrow (-x)
When you need to know the size of the arrows (or the magnitude of the vectors) then you CAN just look at the geometry. x and y are at 90° and equal in size (what we can call unit vectors) so the red one is √2 long. (Pythagoras, 12 + 12 = (√2)2 )
emhelp100 said:
no
Perhaps you should take a look into this and related ideas. Hyperphysics is probably as good a place to start as any.
emhelp100 said:
no
Then I suggest that you try to find that out first. Without that, all the talk of vector addition of both contributions will be useless. See, for example, the Khan academy video on this subject.
  • · Replies 28 ·
  • · Replies 25 ·
  • · Replies 18 ·
