Why Does My Ideal Gas Law Calculation Differ from the Textbook?
The discussion revolves around a calculation error in applying the ideal gas law to find the pressure of carbon dioxide gas. The user initially converted the volume incorrectly, using 4 cubic meters instead of the correct value of 0.0004 cubic meters. After receiving clarification on the volume conversion, the user recalculated the pressure and confirmed the correct answer as approximately 7.3 MPa. The thread highlights the importance of accurate unit conversions in gas law calculations. Ultimately, the user resolved the issue and expressed gratitude for the assistance.
sghaussi
hello all. I'm trying to figure out this problem and it's bugging me because it's soooo simple yet i keep getting the wrong answer. here's the problem:
If 1.00 mol of carbon dioxide gas at 350 K is confined to a volume of 400 cubic centimeters, find the pressure of the gas using the ideal-gas equation.
Okay.. I know that the ideal gas equation will look like this if I am solving for pressure:
p = (nRT)/V
since I want pressure in pascals, then I will convert volume V to cubic meters, and for R constant I will use R = 8.3145 J/mol K
so far this is the information I have:
R = 8.3145 J/mol K
T = 350 K
n = 1.00 mol
V = 4 cubic meters
When I try and solve for pressure, I get 727.5 pascals. I did this 5 times, and I keet getting the same answer. however the book is telling me I'm wrong. Am I not understanding this correct? could this be one of those times the book is wrong? I hope someone can help!
Your conversion into cubic metres is incorrect, remember it is cubic:
Therefore;
0.0004m^3
Use that value for volume and you should calculate the correct answer, which is 7275187Pa or 7.3MPa.
V = 400 cm^3 = 400 * (10^-2 m)^3 = 400 * 10^-6 m^3 = 0.0004 m^3
I think this is correct value of the volume and if you put it into ideal gas equation you'll get the right answer (i think).
thanks to the both of you for your help. i was able to figure it out.. silly mistake. =) night!
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
