Why you need a integration constant
Vdslaur
Can someone help me with this integration?
Don't understand why you need a integrationconstant.
I would do : RTlnC = U but this isn't correct, you have to put + cte
Why?
Hallo Vdslaur
The derivative of a Cte is 0
When you integrate something, the result is always true up to a cte, since if you derive you will get the same answer back for any cte.
That tells you the potential energy '0' is undefined, it's arbitrary, all that matters are its variations. in general you want to set it 0 at infinity.
oli4 said:
Hallo Vdslaur
I know that you integrate the U but
for exmple : the integration of dx = x + cte
But here the integration gives you : RTlnC +cte
So : dU = d(RTlnC)
Solution after integration of dU = U
Solution after integration of d(RTlnC) = RTlnC + cte
This is right no?
d(RTlnC) = RT d(lnC)
And d(lnC) is the same as dx , so x + cte --> here : lnC + cte
yes, I get it!
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
