Wiring a permanent split capacitor motor
The discussion centers on wiring a 5-wire induction motor from a washing machine, specifically one that operates at 240V and 50Hz, featuring a permanent capacitor and no centrifugal switch. The user seeks guidance on determining the correct connections based on resistance measurements between the motor terminals. The provided resistance values between various wire combinations are noted, and there is a request for a general procedure to identify connections in induction motors using resistance data. The thread also references contributions from a knowledgeable member, Jim Hardy, who had previously shared valuable insights on wiring washing machine motors, although he has since passed away. Users are encouraged to explore past discussions for detailed instructions and guidance on this topic.
ovi85
Greetings
This query is regarding a 5 wire induction motor without a wiring diagram from a washing machine, one permanent capacitor, no centrifugal switch. here its 240v 50hz
I would appreciate someone explaining how to actually figure out the connections after measuring the resistance of the terminals against each other with various ohm readings, I want to learn this procedure.
I will include here the chart from measuring resistance between the wires, and someone could tell me do this and that to get it run, that's ok..
green-brown 92ohm
green-orange 140.1ohm
green-blue 86.9ohm
green-white 73.3ohm
brown-orange 106.1ohm
brown-blue 89ohm
brown-white 75.3ohm
orange-blue 44.8ohm
orange-white 31ohm
white-blue 14ohm
But in general as well if someone could write down instructions of how to figure out the connections in any induction motor when I have the information of the resistance of wires to each other.
Likes Fisherman199, Averagesupernova, berkeman and 1 other person
anorlunda said:
It just so happens that we had a PF regular, Jim Hardy, who posted much information on your question. Using old washing machine motors was one of his passions.
Sadly, Jim passed away this year, but the following PF search will surely find your answer.
https://www.physicsforums.com/searc...e+motor+wiring&c[users]=jim+hardy&o=relevance
This is a good one. A veritable JH textbook.
https://www.physicsforums.com/threa...g-machine-motor-to-power-a-grain-mill.833300/
Likes berkeman
Thanks for your references
Some time ago I posted this Raspberry PI DIY Mass Spec using Raman Scattering. It's was something of a cumbersome project though, needing a 3D printer and special heat-resistant plastic giving of carcinogenic fumes during printing. To be blunt it was also not very mobile and interpreting the results was further cumbersome Recently though, I've been told that Arduino, and it's various sensor packages, has matured to the point where it's a usable alternative. Now I realize that a cigarette...
