Engineering Working out freq for circuit to be in phase
  • Thread starter Thread starter craka
    Circuit Phase
The discussion revolves around calculating the frequency required for an AC circuit to achieve voltage and current in phase. The circuit consists of two parallel branches: one with a resistor and inductor, and the other with a resistor and capacitor. The user has calculated the impedances of both branches but is uncertain about how to express the total impedance in terms of frequency. To find the frequency that results in zero imaginary impedance, the user is advised to equate the imaginary part of the total impedance to zero after expressing it in terms of frequency. The conversation emphasizes the need for clarity in manipulating complex impedances to solve for the desired frequency.
craka
AC circuit Vs is 100V 50Hz and is used as reference.
there are two impedences in parallel, made up of a 5ohm resistor and an inductor reactance = +j2 ohm that is parallel with 3 ohm resistor and a inductor reactance = -j3 ohm (though I though negative imaginary part was for capactance?)
voltage across the 3 ohm resistor is 45 Volts
The branch with the resistor and inductor is called I1 , branch with resistor and capacitor is I2
Is is the total current from supply before the parallel branch.
Please see attachment of circuit
I2 = v/I angle = arctan x/r
Is = Vs/Zt = Vs * 1/ (Z1 parallel Z2) = Z1Z2/(Z1+Z2)
I2 = 45/3 =15A angle = artan -3/3 = -45 degrees
magnitude of Vs = 15 * sqrt(3^2+3^2) = 63.64 volts
Z1 = 5+2j = 5.385 angle 21.8 deg Z2 = 3-3j = 4.234 angle -45 deg
Z1//Z2 = {(5.385 angle 21.8) * ( 4.234 angle -45)}/ {(5+2j)+(3-3j)}
Z1//Z2 = 22.849 angle -23.2 deg / 8.06 angle -7.125
Z1//Z2 = 2.835 angle -16.075 deg
Is = 63.64/(2.835 angle -16.075) = 22.45 angle -16.08 degFrom here is where I'm lost on how to calculate the frequency needed to get this circuit to have current and voltage in phase (zero degrees)
For voltage and current to be in phase, the impedance must be a pure resistance, so the imaginary part of your impedance must be zero.
Since you know the impedances of capacitor and inductor at 50Hz, you can calculate their values.
Write Z1, Z2 and Z1//Z2 as functions of the known values of resistances, inductances and capacitances and the unknown value of frequency. Then calculate the frequency for which the imaginary part of the impedance is zero.
I had worked out the inductance values of components for the known frequency of 50Hz howerver I'm unsure what you mean by "write Z1, Z2 and Z1//Z2 as functions of the known values of resistance, and inductance capacitance and the unknonwn value of frequency".
If you call f the frequency, Z_1=R_1 + 2\pi f L_1.
You have a similar expression for Z_2 and for the parallel of the two. The only unknown is f, that you calculate by making the imaginary part of the impedance equal to zero.
So I have Z1 = 5 + 2pifL and Z2 = 3 + 2pifl but what is the expression for Z1//Z2 with using the above value of Z1 and Z2 ??
No,
Z_1 = 5 +j2\pi f L
Z_2 = 3+\frac{1}{j2\pi f C}
and
Z_1 // Z_2 = \frac{Z_1 Z_2}{Z_1 + Z_2}
from that i get this
<br /> \begin{array}{l}<br /> z_1 //z_2 = \frac{{(5 + j2\pi fL) \times (3 + j\frac{1}{{2\pi fC}})}}{{(5 + j2\pi fL) + (3 + j\frac{1}{{2\pi fC}})}} \\ <br /> = \frac{{15 + j\frac{5}{{2\pi fC}} + j6\pi fL + \frac{L}{C}}}{{8 + j2\pi fL + j\frac{1}{{2\pi fC}}}} \\ <br /> \end{array}<br />
Again I'm stuck. Could you please give me some more assistance thankyou.
Multiply the numerator and denominator of the fraction by the complex conjugate of the denominator. In this way only the numerator will be complex.
Equate the imaginary part of the numerator to zero and calculate the value of f.
