On Maudlin’s Claim: “Richard Feynman’s Big Mistake About Einstein”
This analysis is in response to the YouTube video, “Richard Feynman’s Big Mistake About Einstein” https://www.youtube.com/watch?v=YyhJs_zZxi0, about the famous twin paradox of special relativity (you don’t have to watch the video if you’re familiar with the paradox).
When one twin moves away from the other with uniform relative velocity, the observers at rest with respect to each twin in each of their reference frames make local measurements that show clearly the clocks in the other twin’s reference frame are running slow. As long as the twins occupy inertial reference frames in uniform relative motion, they are both right due to the relativity of simultaneity (paradox of time dilation). Now suppose that one of the twins accelerates (changes from one inertial reference frame to another) allowing him to meet up with his brother. In that case the twin that accelerated is in fact younger than his brother when they meet. Does this mean that the accelerated twin’s clock was really running slower all along? Feynman says “no,” if there is no acceleration, measurements by both twins (and their co-moving friends) legitimately show the other twin’s clock is running slow. Therefore, it is the acceleration that is making the difference. Tim Maudlin says Feynman is wrong, it’s not acceleration, it’s simply a difference in path length through spacetime. Of course, what Tim said is true by definition, but that doesn’t mean that Feynman’s response isn’t true (see https://arxiv.org/pdf/1807.02148 for an extensive analysis). Let’s look at Tim’s car driving analogy to see why Feynman’s answer is absolutely fine.
In the car driving analogy, Tim says the odometer doesn’t care how much you turn the steering wheel, which is true if you’re only concerned about the odometer reading of that car. However, it does matter when we’re trying to find out how much this odometer reading differs from the odometer reading of a car that didn’t have to turn its wheel in getting from Point A to Point B. So, contrary to what Tim says, the difference in path length (difference in proper time) does correspond to bentness (acceleration), i.e., the amount of change in direction (change in velocity). [Obviously, the distance (time) over which that change in direction (change in velocity) occurs also makes a difference and I will address that later.]
For example, suppose Point B is due north of Point A and Car 1 drives straight north from A to B (distance z, say, Figure 1). Now consider different paths from A to B taken by Car 2. In all of these paths, the direction Car 2 departs from Point A is the same, a little east of north, say. If Car 2 doesn’t proceed far in that direction (distance x1, say) before its driver turns the wheel to change its direction towards B (driving a distance y1 from there to get to Point B), then the driver need only turn the wheel a small amount (small bentness in Car 2’s path). And, when the driver of Car 2 gets to B (having driven a distance of x1 + y1), its odometer reading is not much larger than that of Car 1, i.e., (x1 + y1) is only a little larger than z. For the second path for Car 2, the driver goes much farther along the initial direction (x1 increased to x2) before steering Car 2 (changing its direction) towards Point B. In this case, the difference between (x2 + y2) and z has increased in correspondence with the amount of bentness (amount of change in direction for Car 2). You can find the exact mathematical relationship between (x + y) and z based on bentness (angle of direction change for Car 2) using the law of cosines.
Figure 1
The law of cosines says $$z = \sqrt{x^2 + y^2 \: – \: 2xy\cos{(\phi)}}$$ where ø is the angle between lines x and y in the triangle (Figure 1). The bentness of Car 2’s path is the supplementary angle of ø. That is, the amount that Car 2’s original direction from Point A changes to start heading towards Point B is given by 180o – ø. Our equation for the path length difference is then
$$\text{Diff} = (x + y) \: – \: \sqrt{x^2 + y^2 \: – \: 2xy\cos{(\phi)}}$$
When the bentness is zero, ø = 180o and Diff = 0. ø = 180o means there is no change between the direction of line x and the direction of line y, so line x and line y are colinear and lie along line z, which means z = x + y. [Duh.]
Now extend line x2 farther and farther, drawing a line y2 to Point B at various places, until line y2 is horizontal (you now have a right triangle with legs y2 and z and hypotenuse x2, Figure 1). Notice as you move along line x how ø decreases (bentness increases) from its max of 180 deg (lines x and y are both vertical and lie along line z) to a min at the end where line y2 is horizontal. Correspondingly, cos(ø) increases from –1 to something positive at the end, so Diff increases accordingly. [Note: ##\phi## is part of z, which is fixed for all combinations of x and y, so increasing bentness isn’t the cause of increasing Diff, but they are correlated.]
This is the situation Feynman was talking about, so it’s clear what he said isn’t wrong. But, we do have to be careful about making this claim in general. It is possible, for example, to have the same bentness angle for two different path lengths from Point A to Point B. This gets to what I said I was ignoring at the outset, i.e., the space over which the bending takes place. For all the paths discussed above, the bending occurred at one point in space, so it was ok to compare their path length differences versus bentness angle. What happens when the bending takes place over an extended spatial region?
Consider three paths from Point A to Point B where the first path from A to B is a straight (vertical) line of length ##z=\pi## (red Path 1 in Figure 2). Let z also be the vertical coordinate and x be the horizontal coordinate with (0,0) at Point A and define the second path as x = sin(z) (green Path 2 in Figure 2).
Figure 2
The arc length ##\Delta s## for Path 2 from A to B is
$$\Delta s = \int{\sqrt{ds^2}} = \int_{0}^{\pi}\sqrt{g_{\alpha \beta}\frac{dx^\alpha}{dz}\frac{dx^\beta}{dz}}dz$$
With ##g_{11} = g_{22} =1##, ##g_{12} = g_{21} = 0## (2-dim Euclidean metric), ##x^1 = z##, and ##x^2 = \sin{(z)}## we have
$$\Delta s = \int_{0}^{\pi}\sqrt{(+1)\left(\frac{dz}{dz}\right)^2 + (+1)\left(\frac{dx}{dz}\right)^2}dz = \int_{0}^{\pi}\sqrt{1 + \cos^2{(z)}}dz = 3.82$$
which is longer than Path 1 (##\Delta s = 3.14##) corresponding to the fact that the driver is turning their wheel on Path 2, but not on Path 1. Now let the third path (blue Path 3 in Figure 2) be a pair of straight lines, the first at ##45^o## from the vertical to the horizontal (x direction) a distance of ##\frac{\pi}{\sqrt{2}}## and the second line from there a distance of ##\frac{\pi}{\sqrt{2}}## to Point B. This path length is ##\pi \sqrt{2} = 4.44##, which is longer than Path 2 even though its bentness angle is the same as that of Path 2.
That is, the direction of Path 2 starts out with slope +1 (slope of tangent line to second path at A is cos(0) = +1), which is also the slope of the first line segment for Path 3. Likewise, the direction of Path 2 when it gets to B has slope –1 (slope of tangent line to second path at B is ##\cos{(\pi)} = –1##), which is also the slope of the second line segment for Path 3. So, Path 2 and Path 3 both have a bentness of ##90^o##, but Path 2 distributes that bentness over its entire length while Path 3 has all of its bentness at a single point, so bentness per se doesn’t correspond to acceleration. Rather, acceleration corresponds to the overall ‘spatial rate’ of bentness (which you can see in Figure 3 because it’s a true acceleration). Nonetheless, with this caveat, Feynman’s answer is still correct.
The relativistic M4 version (with c = 1) of Maudlin’s car odometer analogy is shown in Figure 3.
Figure 3
The path lengths in M4 get shorter with more acceleration instead of longer with more bentness (as in E2) because the Lorentz signature of the spacetime M4 metric is (-1,1) while that for the purely spatial E2 metric is (1,1). The arc length (proper time) for Path 2 is
$$\Delta \tau = \int{\sqrt{-ds^2}} = \int_{0}^{\pi}\sqrt{g_{\alpha \beta}\frac{dx^\alpha}{dt}\frac{dx^\beta}{dt}}dt$$
With ##g_{00} = -1##, ##g_{11} =1##, ##g_{01} = g_{10} = 0## (2-dim Minkowski space metric), ##x^0 = t##, and ##x^1 = \sin{(t)}## we have
$$\Delta s = \int_{0}^{\pi}\sqrt{-(-1)\left(\frac{dt}{dt}\right)^2 – (+1)\left(\frac{dx}{dt}\right)^2}dt = \int_{0}^{\pi}\sqrt{1 – \cos^2{(t)}}dt = 2$$
The length of Path 3 (light-like path) is zero of course.
In Section IV COMMENTS ON MAUDLIN’S ANALYSIS (p. 14) of https://arxiv.org/pdf/1807.02148, the authors write:
Is acceleration crucial to the twin paradox? Consider the situation in flat infinite spacetime, where no twin ever undergoes acceleration, but they are moving at constant speed relative to each other. Then both twins consider the other to be aging slower, but this is perfectly well understood in special relativity and time dilation. However, without acceleration, the twins never come back together and so this in no way constitutes a paradox. To obtain the paradox, one twin must necessarily undergo acceleration. Period. No acceleration, no paradox.
Maudlin says he can add as much acceleration as he likes to the twin on Path 1 and still have that twin be older than the twin who made the journey. But the authors of https://arxiv.org/pdf/1807.02148 correctly point out:
But where is the paradox in this case? The motion of the two twins is in no sense symmetric. There is no symmetry argument that one could make that would lead to a paradox. Simply we would have to do the calculation of the elapsed proper time of each twin according to each twin and find the obvious fact that twin B ends up younger. This modification of the circumstances does not in the slightest take away from the fact that to do the calculation of the elapsed proper time according to each twin in this case, we must take great care to calculate what happens during the accelerating phases. It is true that when analyzing the problem from the frame of reference of twin A, one can neglect the length of the accelerating part of the travelling twin’s worldline, when it is much shorter than the coasting part (as in Fig(4)), and one does of course find the travelling twin B to be younger. But the presence of acceleration is necessary in even coming up with a paradox at all. This is why introducing multiple periods of accelerations is specious, it has no bearing on the original paradox.
PhD in general relativity (1987), researching foundations of physics since 1994. Coauthor of “Beyond the Dynamical Universe” (Oxford UP, 2018) and “Einstein’s Entanglement” (Oxford UP, 2024).
