Physics Forums Insights
  • Physics
    • Mechanics
    • Thermodynamics
    • Electromagnetism
    • Fluids
    • Optics
    • Particles
    • Quantum
    • Relativity
    • Biophysics
  • Astronomy
    • Astrophysics
    • Cosmology
    • Observing
  • Mathematics
    • Algebra
    • Analysis
    • Geometry
    • Number Theory
    • Probability
  • Computing
    • Programming
    • Electronics
    • Imaging
  • Science Culture
    • Education
    • Careers
    • Philosophy
    • Profiles
    • Trivia
  • Forums
  • Menu Menu
electric potential
Deriving the Cosmic Fluid Equation from Energy Conservation
October 16, 2017/0 Comments/in Cosmology, Physics Articles/by andrewkirk
📖Read Time: 6 minutes
📊Readability: Advanced 📐(contains math) (Technical knowledge needed)
🔖Core Topics: equationuniverseenergyFLRWtensor
Local energy conservation in general relativity (GR), expressed as ##{T^{0b}}_{;b}=0##, combines with the Friedmann-Lemaître-Robertson-Walker (FLRW) metric to yield the relation ##\frac{d}{dt}(\rho R^3)=-p\frac{d}{dt}(R^3)##, where ##\rho## is energy density, ##p## is pressure, and ##R## is the scale factor. This equation, together with the Einstein field equation, is used to derive the Friedmann equations governing the dynamics of a homogeneous, isotropic universe.
  • The derivation starts from the local energy conservation law ##{T^{0b}}_{;b}=0## applied in FLRW coordinates, where the metric tensor components are ##g_{00}=-1##, ##g_{11}=\frac{R^2}{1-kr^2}##, ##g_{22}=R^2r^2##, and ##g_{33}=R^2r^2\sin^2\theta##.
  • The stress-energy tensor for the cosmic fluid is written as ##T=(\rho+p)\vec{v}\otimes\vec{v}+p\,g^{-1}##, with the average four-velocity ##\vec{v}=(1,0,0,0)## following from the isotropy assumption.
  • Working through the Christoffel symbol terms in ##{T^{0b}}_{;b}=0## produces the continuity equation ##\dot{\rho}+3(\rho+p)\frac{\dot{R}}{R}=0##, which rearranges into ##\frac{d}{dt}(\rho R^3)=-p\frac{d}{dt}(R^3)##.
  • In the matter-dominated phase of the universe, pressure ##p## is low compared to density ##\rho## and can be ignored, giving the approximation ##\frac{d}{dt}(\rho R^3)=0##.
  • In the early, radiation-dominated universe, the equation of state for a photon gas or a highly relativistic gas, ##p=frac{1}{3}rho##, leads to ##frac{d}{dt}(rho R^4)=0##.
  • How does local energy conservation lead to the cosmic fluid equation?
  • What does this equation give in the matter-dominated universe?
  • What does this equation give in the radiation-dominated universe?
  • Frequently Asked Questions
    • What is the starting point for deriving the cosmic fluid equation?
    • What form does the stress-energy tensor take in this derivation?
    • What is the resulting continuity equation?
    • What happens to this equation in the matter-dominated phase of the universe?
    • What happens to this equation in the early, radiation-dominated universe?
  • Glossary
The energy conservation rule is ##{T^{0b}}_{;b}=0##. This relation is used to extract information about the equation of state connecting pressure and energy density in a homogeneous, isotropic universe.
FLRW coordinates are used for this derivation, in which the metric tensor components are all zero except for:
$$\begin{align*} g_{00}&=-1, \quad g_{11}=\frac{R^2}{1-kr^2}, \quad g_{22}=R^2r^2, \quad g_{33}=R^2r^2\sin^2\theta\\ \end{align*}$$
Here ##R## is the scale factor, which depends only on ##t##.
The stress-energy tensor is ##T=(\rho+p)\vec{v}\otimes\vec{v}+p\,g^{-1}## where ##\vec{v}## is the average four-velocity of the particles of the fluid which, in the FLRW coordinates, is ##(1,0,0,0)##, because of the isotropy assumption.
The representation of T in FLRW coordinates is a diagonal matrix with elements:
##T^{00}=\rho##, ##T^{11}=p \frac{1-kr^2}{R^2}##, ##T^{22}=\frac{p}{R^2r^2}##, ##T^{33}= \frac{p}{R^2r^2\sin^2\theta}##
Now we write ##0={T^{0b}}_{;b}={T^{0b}}_{,b}+T^{ab}\Gamma^0_{ab}+T^{a0}\Gamma^b_{ab}##
We calculate the three terms in turn.
First, we have ##{T^{0b}}_{,b}={T^{00}}_{,0}=\frac{\partial\rho}{\partial t} = \dot{\rho}## because T inherits a diagonal nature in the FLRW coordinates from ##\vec{v}\otimes\vec{v}## and g.
For the next step we use
$$\begin{align*} \Gamma^0_{ab}&=\frac{1}{2}g^{0s}(g_{as,b}+g_{bs,a}-g_{ab,s})\\ &=\frac{1}{2}g^{00}(g_{a0,b}+g_{b0,a}-g_{ab,0})\\ &=\frac{1}{2}g^{00}(g_{00,b}+g_{00,a}-\delta^a_b g_{aa,0})\\ &=\frac{1}{2}\delta^a_b g_{aa,0}\\ \end{align*}$$
since ##g^{00}## is constant at ##-1##. Hence the second term is:
$$\begin{align*} T^{ab}\Gamma^0_{ab}&=T^{ab}\frac{1}{2}\delta^a_b g_{aa,0}\\ &=\frac{1}{2}T^{aa} g_{aa,0}\\ &=\frac{1}{2}\Big(\rho(g_{00,0})+p \frac{1-kr^2}{R^2}g_{11,0}+\frac{p}{R^2r^2}g_{22,0}+\frac{p}{R^2r^2\sin^2\theta}g_{33,0}\Big)\\ &=\frac{1}{2}\Big(0+p \frac{1-kr^2}{R^2}\frac{\partial}{\partial t}\left(\frac{R^2}{1-kr^2}\right) +\frac{p}{R^2r^2}\frac{\partial}{\partial t}(R^2r^2)+\frac{p}{R^2r^2\sin^2\theta}\frac{\partial}{\partial t}(R^2r^2\sin^2\theta)\Big)\\ &=3p\frac{\dot{R}}{R} \end{align*}$$
The third term is
$$\begin{align*} T^{a0}\Gamma^b_{ab}&=T^{00}\Gamma^b_{0b}\\ &=\frac{\rho}{2}g^{bs}(g_{0s,b}+g_{bs,0}-g_{0b,s})\\ &=\frac{\rho}{2}g^{bb}(g_{0b,b}+g_{bb,0}-g_{0b,b})\\ &=\frac{\rho}{2}g^{bb}g_{bb,0}\\ &=\frac{\rho}{2}\Big(0+\frac{1-kr^2}{R^2}\frac{\partial}{\partial t}\left(\frac{R^2}{1-kr^2}\right)+\frac{1}{R^2r^2}\frac{\partial}{\partial t}(R^2r^2)+\frac{1}{R^2r^2\sin^2\theta}\frac{\partial}{\partial t}(R^2r^2\sin^2\theta)\Big)\\ &=3\rho\frac{\dot{R}}{R} \end{align*}$$
Putting the three terms together, we have:
$$\begin{align*} \dot{\rho}+3(\rho+p)\frac{\dot{R}}{R}=0\\ \end{align*}$$
We can express this in a manner that better reflects the relationship of work and energy by considering the rate of change of energy in a co-moving volume:
$$\begin{align*} \frac{d}{dt}(\rho R^3)&= 3\rho R^2\dot{R}+\dot{\rho}R^3 =R^3\Big(\dot{\rho}+3\rho\frac{\dot{R}}{R}\Big) = -3p R^3\frac{\dot{R}}{R}\\ &=-3p\dot{R}R^2=-p\frac{d}{dt}(R^3)\\ &\textrm{In summary:}\\ \frac{d}{dt}(\rho R^3)&=-p\frac{d}{dt}(R^3)\\ \end{align*}$$
The left-hand side is the increase in energy in the co-moving volume as it expands and the rightmost formula is the negative of the work done in the expansion.
In the current universe, in which most mass-energy is matter, and it is very sparsely distributed on average, average pressure ##p## is low compared to ##\rho## and can be ignored, so we get the approximation ##\frac{d}{dt}(\rho R^3)=0## in the matter-dominated phase of the universe.
In the early universe, there was not much matter and such particles as there were would be travelling very fast. Hence the equation of state for a photon gas or a highly relativistic gas applies, which is ##p=\frac{1}{3}\rho##. Inserting that in the above equation we get:
$$\begin{align*} \frac{d}{dt}(\rho R^3)= -\frac{1}{3}\rho\frac{d}{dt}(R^3)\\ \end{align*}$$
Multiply by ##R## and collect on one side to get:
$$\begin{align*} &R\frac{d}{dt}(\rho R^3)+R\frac{1}{3}\rho\frac{d}{dt}(R^3)\\ &=R\frac{d}{dt}(\rho R^3)+R\frac{1}{3}\rho(3R^2)\dot{R}\\ &=R\frac{d}{dt}(\rho R^3)+(\rho R^3)\dot{R}=\frac{d}{dt}(\rho R^4)\\ \end{align*}$$
So, in the early, energy-dominated era, we have:
$$\begin{align*} \frac{d}{dt}(\rho R^4)&=0\\ \end{align*}$$
The derivation starts from the local energy conservation law ##{T^{0b}}_{;b}=0## applied using FLRW coordinates, where the metric components are ##g_{00}=-1##, ##g_{11}=frac{R^2}{1-kr^2}##, ##g_{22}=R^2r^2##, and ##g_{33}=R^2r^2sin^2theta##, with ##R## the scale factor depending only on ##t##.
The stress-energy tensor is ##T=(\rho+p)\vec{v}\otimes\vec{v}+p\,g^{-1}##, where ##\vec{v}## is the average four-velocity of the fluid particles, which equals ##(1,0,0,0)## in FLRW coordinates because of the isotropy assumption.
Combining the three terms of ##{T^{0b}}_{;b}=0## gives ##\dot{\rho}+3(\rho+p)\frac{\dot{R}}{R}=0##, which can be rewritten as ##\frac{d}{dt}(\rho R^3)=-p\frac{d}{dt}(R^3)##, where the left side is the increase in energy in a co-moving volume and the right side is the negative of the work done in the expansion.
In the current universe, matter dominates and is sparsely distributed, so average pressure ##p## is low compared to density ##\rho## and can be ignored, giving the approximation ##\frac{d}{dt}(\rho R^3)=0##.
In the early universe, particles were highly relativistic, so the equation of state for a photon gas or a highly relativistic gas, ##p=\frac{1}{3}\rho##, applies. Substituting this into the fluid equation and multiplying by ##R## leads to ##\frac{d}{dt}(\rho R^4)=0##.
Glossary
  • FLRW metric (Friedmann-Lemaître-Robertson-Walker metric): the metric tensor describing a homogeneous, isotropic universe, with components ##g_{00}=-1##, ##g_{11}=frac{R^2}{1-kr^2}##, ##g_{22}=R^2r^2##, ##g_{33}=R^2r^2sin^2theta##.
  • Scale factor (##R##): a function of time ##t## only, describing the expansion of the universe in FLRW coordinates.
  • Stress-energy tensor (T): the tensor ##T=(\rho+p)\vec{v}\otimes\vec{v}+p\,g^{-1}## describing the energy density ##\rho##, pressure ##p##, and average four-velocity ##\vec{v}## of the cosmic fluid.
  • Matter-dominated phase: the era of the universe in which average pressure ##p## is low compared to density ##\rho## and can be ignored.
  • Radiation-dominated phase: the early era of the universe in which the equation of state ##p=\frac{1}{3}\rho##, appropriate to a photon gas or a highly relativistic gas, applies.
andrewkirk
andrewkirk
Degree in
Bachelor: Science and Maths; PostGrad: Actuarial
Favorite Area of Science
Mathematics; Physics; Genetics
More Related Articles
  • On Maudlin’s Claim: “Richard Feynman’s Big Mistake About Einstein”
    Tags: energy conservation, FLRW metric, Friedmann equations, Graduate, stress-energy tensor
    Share this entry
    • Share on Facebook
    • Share on X
    • Share on WhatsApp
    • Share on LinkedIn
    • Share on Reddit
    • Share by Mail
    https://www.physicsforums.com/insights/wp-content/uploads/2020/09/electricpotential.png 135 240 andrewkirk https://www.physicsforums.com/insights/wp-content/uploads/2019/02/Physics_Forums_Insights_logo.png andrewkirk2017-10-16 09:00:512026-10-16 09:04:57Deriving the Cosmic Fluid Equation from Energy Conservation
    You might also like
    quantum information How Quantum Information Theory Solves “the only mystery” of Quantum Mechanics
    spacetimecon Struggles with the Continuum: Spacetime Conclusion
    definition differences Yardsticks to Metric Tensor Fields
    Minkowski_Spacetime_2 Learning Fermi-Walker Transport in Schwarzschild Spacetime
    Brachistochrone Explaining the General Brachistochrone Problem
    why quantum Why the Quantum | A Response to Wheeler’s 1986 Paper
    Leave a Reply Cancel reply
    Popular Articles
    • Beginner Telescope Buying Guide: Dobsonians, Binoculars & More
    • Learn About Spacetime Diagrams of Light Clocks
    • How I Stopped Worrying and Learned to Love Orthodox Quantum Mechanics
    • Lewin’s Circuit Paradox: Distinguishing E_s and E_m
    • Can We See an Atom?
    • Did the Big Bang Have a Center? The Physics Explained
    • Explore The Vacuum Fluctuation Myth in Quantum Theory
    • How to Self-Study Calculus: Topics and Book Guide
    • Permanent Magnets Explained by Magnetic Surface Currents
    • The Unreasonable Effectiveness of the Popescu-Rohrlich Correlations
    Physics Forums
    • Classical Physics
    • Atomic and Condensed Matter
    • Quantum Physics
    • Beyond the Standard Model
    • Astronomy and Astrophysics
    • Cosmology
    • Other Physics Topics
    Enter your email address:
    Blog Information
    • Become a Member!
    • Write for Us!
    • Table of Contents
    • Blog Author List
    Popular Topics
    black holes (23) classical physics (35) education (23) FAQ (58) General (230) general relativity (23) Graduate (186) gravity (25) Guide (86) interview (49) mathematics (39) mathematics self-study (21) Physicist (27) Quantum Field Theory (34) quantum mechanics (38) quantum physics (24) relativity (40) Special Relativity (22) Tutorial (147) Undergraduate (288)
    • Link to X
    • Link to Facebook
    • Link to LinkedIn
    Link to: Exam Tips & Test Strategies: Practical Study Techniques Link to: Exam Tips & Test Strategies: Practical Study Techniques Exam Tips & Test Strategies: Practical Study Techniques10mathtips Link to: A Journey to The Manifold SU(2): Differentiation, Spheres, and Fiber Bundles Link to: A Journey to The Manifold SU(2): Differentiation, Spheres, and Fiber Bundles A Journey to The Manifold SU(2): Differentiation, Spheres, and Fiber Bundle...
