How Can You Prove This Hyperbolic Function Identity?
The discussion centers on proving the hyperbolic function identity tan^{-1}x = (1/2)ln((1+x)/(1-x)). Participants explore the relationship between the tangent inverse function and hyperbolic functions, emphasizing the need to demonstrate that tan((1/2)ln((1+x)/(1-x))) equals x. A participant identifies an error in their quadratic equation setup and corrects it to e^(2y)(1-x) = 1+x. The conversation highlights the use of the double angle formula for tangent and the identity for tan((1/2)y) to simplify the proof. The proof process involves substituting hyperbolic expressions and applying trigonometric identities to reach the desired conclusion.
bard
I need help proving this hyperbolic function
Prove that
\tan^{-1}\hbar {x}=\frac{1}{2}\ln\frac{1+x}{1-x}
my work
x=e^y-e^-y/e^y+e^-y
(e^y+e^-y)x=e^y-e^-y
0=e^y-e^-y-xe^y+xe^-y
e^y(e^y-e^-y-xe^y+xe^-y)
e^2y-x(e^2y)-1+x=0
I know i have to use the quadratic equation here
One problem you have is that you have "lost" a sign:
instead of e^2y-x(e^2y)-1+x=0, the correct equation is
e^(2y)- x(e^(2y))-1-x= 0 or, more simply, e^(2y)(1-x)= 1+x
so e^(2y)= (1+x)/(1-x).
, but i am not sure how to proceed with the proof.
To prove this hyperbolic function, we can use the definition of the tangent inverse function, which states that \tan^{-1}x=y if and only if \tan y=x. Therefore, we need to show that \tan \left(\frac{1}{2}\ln\frac{1+x}{1-x}\right)=x.
Using the double angle formula for tangent, we have:
\tan \left(\frac{1}{2}\ln\frac{1+x}{1-x}\right)=\frac{2\tan\left(\frac{1}{2}\ln\frac{1+x}{1-x}\right)}{1-\tan^2\left(\frac{1}{2}\ln\frac{1+x}{1-x}\right)}
Now, let's substitute the value of x=e^y-e^-y/e^y+e^-y that we have obtained from the given equation:
\tan \left(\frac{1}{2}\ln\frac{1+x}{1-x}\right)=\frac{2\tan\left(\frac{1}{2}\ln\frac{1+e^y-e^-y/e^y+e^-y}{1-e^y+e^-y/e^y+e^-y}\right)}{1-\tan^2\left(\frac{1}{2}\ln\frac{1+e^y-e^-y/e^y+e^-y}{1-e^y+e^-y/e^y+e^-y}\right)}
Now, using the identity \tan\left(\frac{1}{2}y\right)=\frac{\sin y}{1+\cos y}, we can simplify the expression further:
\tan \left(\frac{1}{2}\ln\frac{1+x}{1-x}\right)=\frac{2\left(\frac{\sin\left(\frac{1}{2}\ln\frac{1+e^y-e^-y/e^y+e^-y}{1-e^y+e^-y/e^y+e^-y}\right)}{1+\cos\left(\frac{1}{2}\ln\frac{1+e^y-e^-y/e^y+e^-y}{1-e^y+e^-y/e^y+e^-y}\
