Calculating Initial Acceleration: 63g Particle, 59μC Charge
To calculate the initial acceleration of a 63 g particle with a 59 μC charge, Coulomb's Law is applied, resulting in a force calculation of 0.284 N. The mass must be converted to kilograms, leading to the equation 0.063a = 0.284. Upon solving for acceleration, the correct value should be 4.51 m/s^2, but there are concerns about the charge values used in the calculations. The charges should be correctly noted as 59 μC and -27 μC, rather than the incorrectly referenced values. Ensuring accurate charge values and unit conversions is crucial for obtaining the correct acceleration result.
Punchlinegirl
A particle of mass 63 g and charge 59 \mu C is released from rest when it is 71 cm from a second particle of charge -27 \mu C. Determine the magnitude of the initial acceleration of the 63 g particle. Answer in units of m/s^2.
I used Coulomb's Law, F= 1/4\pi \epsilon_o * (5.9 x10^-6 * -2.7 x 10^-6) / .71^2
I know that E_o = 8.85 x 10^-12.
Solving this gave me .284.
Then I set it equal to ma.
63 a = .284
Solving for a gave me .00451 m/s^2.
Can someone tell me what I'm doing wrong?
Make sure the units are correct. If the force is in N, which it appears to be, then the mass must be in kg (0.063 kg = 63 g).
Perhaps it would be helpful to keep a chart of cgs and mks units available.
so if the rest of my setup is right, I get .063a= .284.
Solving for a gives me 4.51 m/s^2, which still isn't right.
Am I doing something else wrong?
59 microCoulombs = 59.E-6 C , not 5.9E-6 C
same for the 27 uC .
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
