Thermodynamics: Entropy and specific heat
The discussion revolves around the confusion regarding entropy change equations in thermodynamics, specifically the differences in formulations based on moles versus mass. The first equation uses moles of gas and incorporates specific heat at constant volume (C_V) and the gas constant (R), while the second equation uses mass and includes isobaric specific heat (c_p). The user seeks clarification on how these specific heats relate to entropy change and acknowledges the relationship between C_p, C_V, and the gas constant (R). Ultimately, the user realizes that the equations are consistent when considering the different measures of gas amount and the definitions of specific heats. Understanding these relationships clarifies the application of specific heats in entropy calculations.
Pandris
Hi here!
(before scriptum. Sorry for my lousy English and LaTex.)
I am a bit confused about entropy change statements:
In most textbooks is given:
\Delta S = n (C_V ln \frac{ \ T_{2}}{T_1} + R ln \frac{ \ V_{2}}{V_1})
where n - moles of gas. And dimension of entropy is [J/K]
But now I have one book there entropy change is defined using specific heats:
<br /> \Delta S = m (c_v ln \frac{ \ p_{2}}{p_{1}} + c_p ln \frac{ \ V_{2}}{V_{1}})<br />
where m - mass of gass, and dimension is [J/(kmol*K)]
I can't understand where this isobaric specific heat gets here!
Ok, I understand that these entropies essentially are given for different measures of amount of gass. First is given for moles, but second for kilograms. (am I right??)
But how to involve specific heats there is obscure for me.
Thanks!
Oh my!
Am I blind or what?!
Everything works out if take in mind that
<br /> C_p - C_V = R<br />
and
<br /> c_v = \frac { \ C_{V}}{ \mu}<br />
That's it! Sorry for buzzer!
