What is the Angular Speed of a Rotating Hoop with Given Radius and Mass?
The discussion revolves around calculating the angular speed of a rotating hoop with a radius of 8.00 cm and mass of 0.180 kg after it descends 95.0 cm. The initial approach incorrectly assumed that kinetic energy was zero, leading to confusion about angular speed. The user attempted to apply formulas related to a yoyo, but struggled to connect angular speed and linear speed due to a lack of known variables. The descent of the hoop is influenced by gravitational force and its moment of inertia, complicating the calculations. Ultimately, the user seeks clarification on deriving the angular speed and the speed of the hoop's center.
Heat
A string is wrapped several times around the rim of a small hoop with radius 8.00 cm and mass 0.180kg. The free end of the string is held in place and the hoop is released from rest (the figure View Figure ). After the hoop has descended 95.0cm, calculate
the angular speed of the rotating hoop and the speed of its center.
First attempt was like this
I thought that KE is 0 at initial ,and thought that I could get angular speed this way, but that would just give me that angular speed is 0. :O
Then I tried a formula given by the book for a yoyo, which is vcm = sqrt (4/3gh)
that did not result, and then is another formula that vcm = R(omega)
I don't have omega, and don't have vcm. So I can't use it at this instance. :(
The hoop is decending under the force of gravity by virtue of its weight, mg. At the same time, it is unraveling the string. It's vertical velocity is the same as the tangential velocity (speed) at it's radius. And then there is the rotational inertia to consider.
For moments of inertia and rotational motion equations, see -
http://hyperphysics.phy-astr.gsu.edu/hbase/mi.html
i don't get it..so the angular speed of the rotating hoop w = ?
and
the angular speed of the speed of its center v = Square_Root_Of_((4/3)gh) ... ??
