Certain isotope tell you that the decay rate decreases
The discussion revolves around the decay rate of a certain isotope, which decreases from 8337 decays/minute to 3174 decays/minute over 5 days. The user initially calculated the decay constant (lambda) and expressed confusion about it being negative, questioning the validity since half-life should be positive. It was clarified that if the initial activity (R0) is incorrectly assigned as the lesser value, it could lead to a negative lambda, indicating an increase rather than a decrease in activity. The importance of consistent unit conversion was emphasized to ensure accurate calculations. Ultimately, understanding the correct application of the decay equation is crucial for determining the half-life correctly.
xinlan
Measurements of a certain isotope tell you that the decay rate decreases from 8337 decays/minute to 3174 decays/minute over a period of 5.00 days.
R=Ro.e^-lamda/t
then T1/2 = ln(2)/lamda
I converted all the units..
t = 5 days = 432000 seconds
R = 8337 decays/minute = 52.9 decays/s
Ro=3174 decays/minute = 138.95 decays/s
I did:
R=Ro.e^-lamda/t
52.9=138.95 . e^-lamda*432000
lamda = -1.86*10^-6
I am confused.. the lamda should not be a negative number right?
because half-life should be a positive number..
please help me..
Well, if one take R0 to be the lesser activity and the later activity to be greater, then one will get a negative lamdba since the activity is increasing.
Usually R(t) < R0, i.e. R(t) is decreasing from R0.
If one takes the ln of the decay equation, one can make it linear.
Start with R0 = 8337 decays/minute, then R(t=5days) = 3174 decays/minute, but make sure units/time are on the same basis.
I should convert all the units right?
then if the lamda is negative, the half-life will be negative, and should I just plug in the minus sign as well on the computer?
I got it.. :)
