Advice on my Tennis Ball Launcher
The discussion focuses on designing a tennis ball launcher that can shoot balls over 90 meters while ensuring accuracy to hit a pie pan 10 meters away. The launcher must be safe, avoiding explosive, combustion, or electrical mechanisms, and should be fired from a distance of 2 meters. Suggested designs include a crossbow effect, catapults, and trebuchets, with materials like PVC and wood being considered for ease of construction. The base dimensions are limited to 0.5 meters by 0.5 meters, with a maximum height of 2 meters. The user seeks beginner-friendly instructions, videos, and references to assist in building the launcher.
MMAiNNovaToR
Advice on my Tennis Ball Launcher...That Shoots 90 Meters
It can't rely on anything explosive, combustion, or electricity (anything dangerous) and has to be fired from a distance of 2 meters.
2 parts: Distance- It has to shoot 90 or more meters
Accuracy- shoot the tennis ball into a pie pan 10 meters away
I could use any design but don't know what design is best suited for this project. I was planning on building a triangular type base, firing the ball at a 45 degree angle and using some type of crossbow effect to shoot it. Some materials I have in mind so far are PVC and wood; I am open to any material that is easy for a beginner to work with, but I don't know what to shoot the tennis ball with if I do a crossbow effect. Some other designs that are reccomended are catapults and trebuchets. Again, I am open to any design that is easy for a beginner to build. The base can't be bigger than .5 meters by .5m. Max height is 2 meters.
Any suggestions would help-including videos, images, instructions, notes, references, etc. I am a Junior at high school with no experience in constructing these types of mechanisms, so I want to build something quite simple and suitable for me. Thanks.
This thing needs to fire from far away, and I don't know what to do.
