Newton's 2nd Law Question (2-Dimensions)
The discussion centers on calculating the applied force and normal force acting on a lawnmower being pushed at an angle. The friction force is given as 50.0 N, and the mower accelerates at 0.15 m/s² with a mass of 11 kg. The applied force was calculated to be approximately 151 N, while the normal force was found to be 156 N. However, there is an indication of an error in the problem's solution regarding the normal force calculation. The correct approach involves balancing the forces in the vertical direction to determine the normal force accurately.
chroncile
A proud homeowner is out mowing their lawn. If the force of friction on the mower is 50.0 N and it is accelerating forward at 0.15 m/s2, what is the magnitude of the applied force if the owner is pushing on the handle of the mower at an angle of 70 below the horizontal? How big is the normal force acting on the lawnmower? The mass of the lawnmower is 11 kg.
Fnet = Fapp + Ff
Fnet = ma
Fg = mg
Fnet = Fapp + Ff
0.15 * 11 = Fappx + (-50.0)
1.65 + 50.0 = Fappx
Fappx = 51.65 N
Fappy = 51.65 * tan(70) = 142 N
Fapp = SquareRoot (51.652 + 1422)
Fapp = 151 N
0 = Fappy + Fn + Fg
0 = 142 + Fn + 11*9.8
Fn = -250 N
Correct answers are:
Fapp = 151 N
Fn = 156 N
How would you get the normal force?
Fnet = Fapp + Ff
Fnet = ma
Fg = mg
Fnet = Fapp + Ff
1.65 + 50.0 = Fappx
Fappx = 51.65 N
Fapp = 151 N
0 = Fappy + Fn + Fg
Fn = -250 N
Fapp = 151 N
Fn = 156 N
Your way:smile:. There seems to be an error in the problem solution.
