Electric circuit, remove a bulb
In the discussed electric circuit, three bulbs are arranged with Bulb1 in series and Bulb2 and Bulb3 in parallel. When either Bulb2 or Bulb3 is disconnected, the total resistance of the circuit changes, affecting the current flow. Disconnecting Bulb3 increases the total resistance, resulting in less current through Bulb1, causing it to shine less brightly. Conversely, Bulb2 receives a higher voltage after Bulb3 is removed, allowing it to shine more brightly. The calculations presented support these conclusions, indicating that the understanding of the circuit dynamics is correct.
GatorPower
Hi. I seek your opinions on a "simple" circuit:
Voltage..... Bulb2...Bulb3
|....Bulb1... |
Here one have a voltage (battery) and three bulbs: Bulb1, Bulb2, Bulb3. We think of the bulbs as Ohm-resistances where Bulb1 is a series resistance while bulb2 and bulb3 is in parallell.
The resistance is exactly the same in all bulbs and we turn the battery on so that the bulbs light up. The question is what happens when we disconnect either bulb2 or bulb3. Will bulb1 light stronger or weaker? Bulb2/Bulb3 light stronger or weaker?
As I understand it:
Total resistance is with the resistance of each bulb for simplicity equal 2 Ohm and V = 10 Volts:
Rtot = R1 + (1/R2 + 1/R3)^-1
Rtot = 2 + 1 Ohm = 3 Ohm
I = V/Rtot = 10/3 A
Disconnect Bulb3:
Rtot = R1 + R2 = 4 Ohm
I = 10/4 A
Then Bulb1 will not shine as much as it did before since there is less current going through.
Vbulb2 = 20/6 Volts before bulb3 is disconnected
Vbulb2 = 20/4 Volts after
I = V/R = 20/12 A before, 20/8 A after
Hence Bulb2 shines stronger.
Please offer your opinions on this, I'm not sure if this is correct.
Looks good to me.
