Current of Electricity: electrons
To determine how many electrons pass a point in a wire carrying a current of 2.0 A for 1.0 hour, the total charge (Q) is calculated using Q = I × t, where t is converted to seconds (3600 seconds). The number of electrons is then found by dividing the total charge by the charge of a single electron (approximately 1.602 x 10^-19 C). After correcting a calculation error regarding the time conversion, the correct answer is found to be 1.3 x 10^19 electrons. The final answer aligns with option C. This illustrates the importance of careful unit conversion in electrical calculations.
balibone
A wire carries a current of 2.0 A for 1.0 hour. How many electrons pass a point in the wire in this time?
A
1.2 x 10-15
B
7.2 x 103
C
1.3 x 1019
D
4.5 x 1022
Q=I/t
Q=2(60)=120
number of electrons= 120/1.60217733 × 10-19= but the answer isn't any of the options..ok i realized my super careless mistake (1hr=60s)
(1hr=60s)
Is it correct?
