Difference between Electric flux density,electric field strength .
Electric flux density and electric field strength are closely related concepts in electromagnetism, with electric flux density representing the total electric field passing through a surface area. Electric flux is measured in volt-metres, while magnetic flux is measured in webers. Magnetic field strength (H) and magnetic flux density (B) are distinct, with H representing the intensity of the magnetic field and B being the flux per unit area. The relationship between them is defined by the equation H = B/μ, where μ is the permeability of the medium. Understanding these distinctions is crucial for clarity in electromagnetism discussions.
sachin123
Difference between Electric flux density,electric field strength...
I want to know the difference between,electric flux density and electric field strength.Are they the same?
And also,there is a magnetic field(measured in Tesla),magnetic flux(in Weber),magnetic flux density(Weber per m2),magnetic field strength(measured in Tesla again?).
I am finding these very confusing.Can someone clear this out?
Thanks
hi sachin123! :smile:
from the pf library on flux …
In electromagnetism, flux always means total flow through a surface (a scalar), and is measured in webers (magnetic flux) or volt-metres (electric flux).
Flux is the amount of a vector field going through a surface: it is the integral (over the surface) of the normal component of the field​
flux density (btw, this is density per area, not per volume) is the same as the field …
flux = ∫ field "dot" area, so field = flux per area = flux density …
tesla = weber/metre2 :wink:
(and "strength" just means "amount" …
you can leave it out when writing, and ignore it when reading :wink:)​
I am clear with Electric field strength(=electric flux density) and electric flux.
1.)Does it mean that magnetic field strength=magnetic flux density?
and...
from what you said,
magnetic field strength = magnetic field.But,here is what my book says:
Magnetic field strength (H)=B/\mu
where B is magnetic flux density.
Now weren't they supposed to be the same?(magnetic flux density and Magnetic field strength)
ah, i see …
your book is calling H (in amps per metre) the magnetic field strength …
i haven't come across that before …
i've seen magnetic field intensity for H, but not strength :redface:
oh, in that case forget what i said about ignoring the word "strength": clearly some books are using it to distinguish H from B (in webers per metre squared)
(but the best way to distinguish them is to call them the H-field and the B-field :wink:)
So,to conclude it,
magnetic flux is number of magnetic lines passing through surface area...
unit:weber
magnetic flux density is number of magnetic lines passing through unit surface area...
unit:weber per (m square)
magnetic field is same as magnetic flux density
magnetic field strength =magnetic field intensity is H =B/(mu)
unit:A per m
Is it correct?:smile:
'mu' i meant as \mu
