College Physics Problem Capacitor / Inductor
The discussion revolves around solving a physics problem involving a 10.0 microfarad capacitor charged to 170 microcoulombs and connected to a 4.00 mH inductor. Participants emphasize the importance of conservation laws and energy exchange between the capacitor and inductor, leading to oscillations of current and voltage. The initial calculations for voltage across the capacitor and resonance frequency are presented, but some participants point out errors in the approach, particularly regarding the transient nature of the circuit. The maximum current in the inductor is calculated, but it is suggested that the method used may not accurately reflect the instantaneous values required. The conversation encourages a focus on energy storage principles to clarify the relationships between current, voltage, and energy in the circuit.
aamartineng17
A 10.0 Microfarad Capacitor is charged to 170 Micro Coulombs then connected across the ends of a 4.00mH inductor.
(a) Find the maximum current in the inductor.
(b) At the instant the current in the inductor is maximum. How much charge is on the capacitor parallel plates?
(c) Find the maximum potential across the capacitor.
(d) At the instant the potential across the capacitor is maximum. What is the current in the inductor?
(e) Find the maximum energy stored in the inductor.
(f) At the instance the energy stored in the inductor is maximum. what is the current in the circuit?
I am really stuck on calculating this physics problem, especially part a. Could someone please give me some assistance in calculating this Physics Problem. I really appreciate your help. Thanks
Hi aamartineng17, Welcome to Physics Forums.
These kinds of problems are often easier if you think in terms of conservation laws. Here there are two energy storage devices (a Capacitor and an Inductor) which are going to trade energy back and forth. The result is oscillations of current and voltage.
When the circuit begins operation, only the capacitor has any energy stored since it has an initial voltage; There's no current flowing so the inductor has no stored energy.
What do you know about energy for these devices? Do you have formulas?
Hello Everyone,
For the Following Physics Problem listed below:
I tried solving the problem, here were my results:
(Part a)
*Note: That the charged Capacitor is connected across an inductor.
The Equation for the voltage of a capacitor is the following: V = Q / C
For this problem Q = 1.7 x 10^-4 C, C = 1 x 10^-5 F
I calculated the Voltage of Capacitor to be:
V = Q / C = 1.7 x 10^-4 C / 1 x 10^-5 F = 17 Volts
I know that since the Capacitor is connected across the inductor I know that the inductor will then have a potential difference of 17 Volts.
**Note: At the instant when the charge on the capacitor reaches zero, Q = 0, the current in the Inductor has reached its max value, but at this instant the current in the Inductor is not changing, [-L (Delta I / Delta t) = Q / C = 0). At this moment, the magnetic field B in the inductor is also a maximum.
*** Note: I then calculated the Resonance Frequency using the following equation:
f = fo = (1 / 2* pie) * sqrt (1 / L * C)
f = fo = (1 / 2 * pie) * sqrt ( 1 / (4 x 10^-2 H) * (1.7 x 10^-4 C)
f = fo = 193 Hz
I then used the following equation
XL = 2 * pie*f* L = 4.851 ohms (the reactance for inductor)
I then used the Equation V = I * XL , to calculate the max current in inductor:
I = V / XL = 17 V / 4.851 ohms = 3.50 A (Calculated Max Current of Inductor)
I would really appreciate it if someone could please tell me if this is the correct way to solve (Part A) of this problem. Thanks Again for your time and help. I really appreciate and value your time and help!
When the charge reaches zero on the capacitor and the inductor has its maximum current, the voltage across the capacitor (and thus the inductor, too) will be zero. So your solution method for the current doesn't look right. (Also, it implies a steady-state AC situation, and you're looking for an instantaneous value in a transient situation).
Also, you appear to have plugged in the charge on the capacitor rather than the capacitance in your workings for the resonance frequency.
I might suggest that you look at it from an energy point of view. Capacitors store energy in electric fields, so their maximum energy stored corresponds to when they have a maximum potential difference across them. Inductors store energy in magnetic fields, and have maximal energy stored when their currents are maximum...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
