Another Double Check FBD String Tension
The discussion focuses on calculating the tension in a cable connecting two masses, m1 (5 kg) and m2 (6 kg), on frictionless surfaces at angles θ1 (60°) and θ2 (70°). The equations derived show that the tension (FT) is influenced by the gravitational force and the acceleration of the masses. After setting the equations equal, the acceleration is determined to be 1.16 m/s², leading to a final tension of 48.2 N in the cable. Concerns are raised about using the same variable names for different mass quantities, but clarification is provided that FT and acceleration can be consistently used across both masses. The calculations and results are confirmed to be correct.
Inferior Mind
Calculate the tension in the cable connecting the two masses. Assume all surfaces are frictionless.
FBD
m1 = 5 kg
θ1 = 60°
m2 = 6 kg
θ2 = 70°
Equation 1 ~
FT - Fg = ma
FT - mgSinθ = ma
FT = 5a + 5(9.8)Sin60
FT = 5a + 42.44
Equation 2 ~
Fg - FT = ma
mgSinθ - FT = ma
6(9.8)Sin70 - 6a = FT
FT = 55.25 - 6a
~Set Equations Equal to Each Other ~
5a + 42.44 = 55.25 - 6a
11a = 12.81
a = 1.16 m/s2
~Sub into Eq to find Force Tension on da String Son !~
5(1.16) + 5(9.8)Sin60 = FT
FT = 48.2 N
FBD
m1 = 5 kg
θ1 = 60°
m2 = 6 kg
θ2 = 70°
Equation 1 ~
FT - Fg = ma
FT - mgSinθ = ma
FT = 5a + 42.44
Equation 2 ~
Fg - FT = ma
mgSinθ - FT = ma
FT = 55.25 - 6a
11a = 12.81
a = 1.16 m/s2
FT = 48.2 N
The results looks correct.
Comment: If I were grading this, I would be concerned that you are using the same variable names for mass 1 quantities and mass 2 quantities, particularly Fg and m .
Thanks for the input, I will make amends in future questions.
To be more specific: FT and a are the same in magnitude for both masses, so it's fine to use the same variable name for them.
