Arc length problem with a thorny integration
The discussion centers on calculating the arc length of a particle's path defined by the parametric equations \(\gamma(t) = \left(\frac{t^2}{2}, t, \ln(2t)\right)\) for \(t\) in the interval \([1, 4]\). The speed differential is derived as \(ds = \sqrt{t^2 + 1 + \frac{1}{t^2}} dt\), leading to the arc length formula \(\ell = \int_1^4 \sqrt{t^2 + 1 + \frac{1}{t^2}} dt\). The discussion highlights the challenge of evaluating this integral, with attempts at trigonometric substitutions and the use of Wolfram's online integrator yielding complex results. A key insight is recognizing that \(t^2 + 1 + \frac{1}{t^2}\) can be rewritten as \((t + \frac{1}{t})^2 - 1\), which simplifies the integration process.
  • Understanding of parametric equations in calculus
  • Knowledge of arc length calculation techniques
  • Familiarity with integration methods, including trigonometric substitution
  • Experience with symbolic computation tools like Wolfram Alpha
  • Explore integration techniques for complex functions
  • Learn about parametric curves and their properties
  • Study the use of substitutions in integral calculus
  • Investigate the application of Wolfram Alpha for solving integrals
Students and educators in calculus, mathematicians tackling integration problems, and anyone interested in the geometric interpretation of parametric equations and arc length calculations.
aucuneidee
So, the question gives a particle traveling over a path [itex]\gamma[/itex], and I need the arc length.
The path is [itex]\gamma(t) : [1,4] \to ℝ^3, t \mapsto (t^2/2, t, ln(2t))[/itex].
We want the arc length over [itex]1 \le t \le 4[/itex].
First, the speed differential: [itex]ds = \left\| \gamma'(t) \right\| dt = \sqrt{t^2 + 1 + 1 /t^2} dt[/itex]
Now, the arc length. [itex]\ell = \int_\gamma ds = \int_1^4 \sqrt{t^2 + 1 + 1 /t^2}dt[/itex].
But that's where the fun ends. I've tried a bunch of trig substitutions (e.g. [itex]t=\tan u[/itex]), to no avail.
I also tried Wolfram online integrator, which returned a mess of symbols -- this problem should have a (reasonably) simple analytic solution.
Any ideas, anyone? I'd really appreciate any help!
Didn't you notice that [itex]t^2+ 1+ 1/t^2= t^2+ 2+ 1/t^2- 1= (t+ 1/t)^2- 1[/itex]?
I had, but didn't realize it would help. I'll play around and see what I can come up with. :)
Thankyou for the quick response!
  • · Replies 105 ·
11K
