Max Horizontal Force for Two Blocks to Accelerate Without Slipping
In summary: So to clarify for anyone reading this in the future: When the blocks are moving in tandem, the total mass can be treated as one block of mass M1+M2, and the maximum force is µg(M1+M2). When the blocks are not moving in tandem and you're instead applying the force to the top block, the maximum force is µg(M1/M2)M1 = µgM1^2/M2.In summary, the problem involves two blocks of masses M1 and M2 on a frictionless table, with a coefficient of friction µ between the blocks. The maximum horizontal force that can be applied to the lower block without causing slipping between the blocks is given by Fmax
Patta1667
28
A block of mass [tex] M_1[/tex] rests on a block of mass [tex] M_2[/tex] which lies on a frictionless table. The coefficient of friction between the blocks is [tex] \mu [/tex]. What is the maximum horizontal force which can be applied to the lower ([tex] M_2 [/tex]) block for the blocks to accelerate without slipping on one another?
The acceleration of the two blocks (assuming they're not slipping) is [tex] a = \frac{F}{M_1 + M_2} [/tex], and you want the upper block ([tex]M_1[/tex]) to not slip, that is, the acceleration times [tex] M_1 [/tex] must be less than or equal to the frictional force. When the blocks start slipping, [tex] M_1 a = \mu M_1 g [/tex] where the frictional force holding the upper block is [tex] f = \mu M_1 g [/tex]. This means that [tex] a = \frac{F_{max}}{M_1 + M_2} = \mu g [/tex], or [tex]F_{max} = \mu g (M_1 + M_2) [/tex].
I'm not sure if this answer is right, but it makes intuitive sense when looking at the final equation. Thanks for any help!
That is correct. :) Just to set your mind at ease, here's what you said in a more formal form:
The maximum force that static friction can enact on the upper block, and the corresponding acceleration at which it would travel are:
fs max = µs*M1*g --> amaxsg
Now we have our maximal acceleration. We see what the form of the acceleration is for the two blocks moving in tandem, equate the two, and find out Fmax.
Since they are moving in tandem, we can refer to them as one block of mass M1+M2
a = F/(M1+M2) = amax = µsg
Fmax = µsg(M1+M2) //
Thank you RoyalCat. Here's the catch: The problem originally came in two parts, the first part being that a force F is applied to the upper block, all other components are the same. Intuitively I saw [tex]F_{max} = \mu M_1 g [/tex] in this new situation (both blocks sitting on a frictionless table, recall).
The text gives [tex] M_1 = 4, M_2 = 5 [/tex] (M1 on top), and says that a force of 27 N applied to the lower block causes them to slip. Thus, from the original formula [tex] F_{max} = \mu g (M_1 + M_2) [/tex] I calculated the appropriate [tex] \mu = 0.306 [/tex]. Then it asks for the maximum force which applied to the upper block, so plugging in [tex] \mu = 0.306 [/tex] should give the text's answer. [tex] F_{max} = (0.306)(9.8)(4) = 12 N [/tex] but the "correct answer" is 21.6 N.
Either my formula for the top-block force is wrong, we're both wrong for the bottom formula, or the text's answer is wrong, or a combination! What do you think?
Oh, I see it now.
If you're pushing the top block at just enough force so that it doesn't slip, what forces are acting on the bottom block, and in what acceleration do they result?
Now remember that the acceleration of the bottom block is shared by the top block, and since they are moving in tandem, the force acting on them needs to provide the acceleration for both of them.
Right, that was pretty silly of me. Thanks again - answer makes sense now.
[tex] F_{max} = (M_1 + M_2)a [/tex]
[tex] M_2 a = \mu g M_1 \implies a = \mu g \frac{M_1}{M_2} [/tex]
[tex] F_{max} = (M_1 + M_2) \mu g \frac{M_1}{M_2} = 21.6N [/tex]
You're welcome. :) It didn't come intuitively to me either, heh.
Related to Max Horizontal Force for Two Blocks to Accelerate Without Slipping
1. What is the definition of "Max Horizontal Force for Two Blocks to Accelerate Without Slipping"?
The Max Horizontal Force for Two Blocks to Accelerate Without Slipping refers to the maximum force that can be applied to two blocks in contact with each other, such that they both accelerate without slipping on a horizontal surface.
2. How is the Max Horizontal Force calculated?
The Max Horizontal Force is calculated by taking into account the coefficient of friction between the two blocks, the mass of each block, and the acceleration due to gravity. It can be calculated using the formula F = μmg, where μ is the coefficient of friction, m is the mass of the blocks, and g is the acceleration due to gravity.
3. What conditions must be met for the two blocks to accelerate without slipping?
For the two blocks to accelerate without slipping, the force applied must be less than or equal to the Max Horizontal Force calculated for the given conditions. Additionally, the coefficient of friction between the blocks and the surface must be high enough to prevent slipping.
4. Does the Max Horizontal Force change if the surface or the blocks' mass changes?
Yes, the Max Horizontal Force will change if the surface or the mass of the blocks changes. As the coefficient of friction and the weight of the blocks are factors in the calculation of the Max Horizontal Force, any changes in these values will affect the result.
5. What are some real-life applications of understanding the Max Horizontal Force for Two Blocks to Accelerate Without Slipping?
Understanding the Max Horizontal Force is important in various industries, such as construction and transportation. It can help engineers determine the maximum load that can be placed on a surface without causing slipping or damage. It is also relevant in designing vehicles and machinery that need to maintain traction while accelerating.
