Calculate the KE of an electron emitted from the beta decay of a neutron
The discussion revolves around calculating the maximum kinetic energy (KE) of an electron emitted during the beta decay of a neutron. Participants clarify that the energy mass equivalence of 931.5 MeV/amu indicates that each atomic mass unit (amu) corresponds to this energy value. The beta decay equation is provided, and attempts to calculate the KE using mass-energy equivalence are discussed. A participant expresses confusion about converting units and how to apply the energy mass equivalence correctly. Ultimately, the key takeaway is that to find the KE, one must multiply the mass difference in amu by 931.5 MeV/amu to obtain the energy in MeV.
chirumu
What is the maximum kinetic energy (in keV to 3 significant figures) of an electron emitted in the beta decay of a free neutron? Write down the decay equation using accepted notation.
Mass of a Neutron: 1.008665 u
Mass of a Proton: 1.007276 u
Mass of an Electron: 0.00054858 u
the energy mass equivalence for this question is 931.5 MeV/amu
e=mc^2
beta decay equation:
A / Z X -> A / (Z+1) Y + e- + v
by A / Z i mean A over Z, not divided by.
i really have no idea how to do this. But:
for the neutron:
e= mc^2
e= (1.008665 u)(2.9979x10^8 m/s)^2
e= 9.065x10^16 amu m^2 s^2
for the proton:
e= (1.007276 amu)(2.9979x10^8 m/s)^2
e= 9.052x10^16 amu m^2 s^2
for the electron:
e=mc^2
e= (0.00054858amu)(2.9979x10^8 m/s)^2
e= 4.93x10^13 amu m^2 s^2
if i subtract the energy of the proton from the neutron you get the energy of the electron and its KE:
9.052x10^16 - 9.065x10^16
= -1.2x10^14 amu m^2 s^2
then to get the ke of the electron:
-1.2x10^14 - 4.93x10^13
= -1.693x10^14 amu m^2 s^2
I know the answer is wrong because i haven't converted amu into energy. I don't get fully what they mean by "if the energy mass equivalence is 931.5 MeV/amu". I could probably convert amu -> kg, then kg -> J, then J -> MeV, then MeV -> keV BUT, I'm don't think that's what they're asking given they've stated "the energy mass equivalence is 931.5 MeV/amu" does that just mean that for 1 unit of amu = 931.5 OR to divide 931.5 BY the value I've obtained in amu.
Insight appriciated :( i am quite stuck.
Yes, it means that there are 931.5 MeV for every amu. Think about it from an algebraic point of view:
k = 931.5 MeV/amu
2 amu * k → 2 amu * 931.5 MeV / amu
The 'amu's cancel out to leave MeV
2 * 931.5 MeV → 1863 MeV
NR
