Calculating Bright Fringes in Reflected Light from Two Flat Plates at an Angle
The problem involves calculating the number of bright fringes observed in the reflected light from two flat glass plates that are inclined, creating a variable air gap. The setup includes parameters such as the thickness of the air gap, the length of the plates, and the wavelength of the light used.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the phase changes occurring in the reflected light and the relationship between the thickness of the air gap and the wavelength. There are attempts to derive equations for constructive interference and the distance between bright fringes.
The discussion includes various approaches to understanding the relationship between thickness and fringe spacing. Some participants suggest different methods for calculating the number of bright fringes, while others explore the implications of changing thickness on the observed pattern. There is no explicit consensus, but multiple lines of reasoning are being explored.
Participants are working within the constraints of the problem, including the specific dimensions of the plates and the wavelength of light. There is a focus on the mathematical relationships involved without resolving the final outcome.
JSapit
Two optically flat plates of glass are separated at one end by a wire of diameter 0.250 mm; at the other end they touch. Thus, the air gap between the plates has a thickness ranging from 0 to 0.250 mm. The plates are 15.0 cm long and are illuminated from above with light of wavelength 550.0 nm. How many bright fringes are seen in the reflected light?
t=m(lambda)
I know that there is two phase changes, so with this apparatus, there has to be a (1/2) added to create constructive interference. I also know that the ray has to travel through the thickness once, and then again, so the distance would be 2t. I tried solving for t via the equation 2t=(m+1/2)(lambda) and solving for t. That gives me the distance, but I'm not sure what to do from there. Am I on the right track?
I'm sure it can be done that way, and it will be a beautiful piece of work, but wouldn't it be easier just to find the distance between bright fringes? That is, how much width is needed to change 2t by one wavelength?
So you mean just set up the equation as 2t=(1+1/2)(550nm)
Like that?
Since that give me the distance, how would I solve for just the bright fringes?
The thickness must CHANGE by 550 nm as you go from crest to crest.
Have to have a formula relating change in t and change in x.
I figured it out. Thanks for your help!
13K
