Calculating Cost of 1KWhr Heat from a Reversible Heat Pump
The discussion centers on calculating the cost of heating using a reversible heat pump operating between two temperature points. A participant initially confuses the efficiency of the heat pump with the motor's efficiency, mistakenly applying the formula for efficiency without considering the correct parameters. The correct approach involves using the coefficient of performance (COP) of the heat pump, which is influenced by the temperatures in Kelvin, and factoring in the motor's efficiency. The net COP is calculated by multiplying the heat pump's COP by the motor's efficiency. Ultimately, the cost of 1 kWh of heat supplied can be determined by the relationship between the COP and the cost of electricity.
h.a.y.l.e.y
A perfectly reversible heat pump heats a building at 20deg from the atmosphere at 5deg. If the heat pump is run by an electrical motor whose efficiency is 80%, what is the cost of 1KWhr of heat supplied? (1KWhr of electricity is 6p)
I am confused by this qn as I thought the efficiency, e = 1-(T1/T2), which in this case would be 0.75 and not 0.8?!
Could someone give me a clue on where I'm going wrong please!
Let's see. You have a perfect reversible heat pump of coefficent of operation COP connected to an electric motor of efficiency \eta_e.
The coefficient of operation of the heat pump is defined as:
COP=\frac{Q_h}{W}=\frac{T_h}{T_h-T_c} being W the work exerted on the cooling fluid.
So that you can work out the COP because you have all temperatures. The net COP of the whole would be:
COP_n=\frac{Q_h}{W_e}=\frac{Q_h \eta_e }{W}=\eta_e COP
so this yield another number.
for Q_h=1KWh the cost of the electrical power which must be supplied is:
C=\frac{1}{COP_n}c being c the cost of 1 KWh of electricity (6p)
You are confusing motor efficiency with the efficiency or coefficient of performance of the heat pump. They are quite different and independent concepts. Also you have to use K not \degree C
The efficiency of the heat pump is given by the coefficient of performance:
cop = \frac{Q_h}{W} = \frac{Q_h}{Q_h-Q_c} = \frac{1}{1 - Q_c/Q_h}
For a Carnot (reversible) cycle, \Delta S = Qh/Th - Qc/Tc = 0[/tex] so:<br /> <br /> Q_c/Q_h = T_c/T_h<br /> <br /> so:<br /> cop = \frac{1}{1 - T_c/T_h}<br /> <br /> Using K, work out the cop. From that you can determine the amount of heat delivered to the building for each joule of work supplied. Since the motor is 80% efficient, for each joule of electrical energy consumed it delivers .8 J of work to the heat pump.<br /> <br /> AM
V Helpful, I can now get the correct answer!
Thanks for your time guys.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
