Calculating FBD Forces for Acceleration: Solution Verification and Analysis
The discussion focuses on calculating the force F required for mass m3 to accelerate upwards at 1 m/s² while considering the effects of friction between the blocks. The user outlines their approach using free body diagrams (FBDs) and equations of motion, but expresses uncertainty regarding the correctness of their solution and the role of friction. Key points include the need to accurately represent the direction of friction forces, particularly how they affect the acceleration of m2 relative to m1. Participants emphasize the importance of balancing forces for all three masses and clarifying the relationships between their accelerations. The conversation concludes with a reminder to ensure all forces and accelerations are correctly accounted for in the FBDs.
shizaep
1)What should F be so that m3accelerates upwards at 1 m/s2?
F = ma
So I start by drawing FBD's for everything:
^^also, there is supposed to be a force of friction to the right on M1, I factored that into my solution but forgot to draw in in the diagram.
Then I proceed to sum the x and y components of the forces where it is relevant.
m3:
ƩFy=m3a1
T-m3g=m3a1
m2:
μkm2g-T=m2a1
m1:
F-Nm3km2g=m1a2
F=(m1+m3)(a2-1)-μkm2g
i got the relationship a2=a1-1
(a2is the acceleration of the big block and a1 is the acceleration of the 2 smaller blocks)
For a final answer I got:
F = (m1+m3)[(μkm2g-m3g)/(m2+m3)-1]-μkm2g
I am not sure if this is correct. May someone verify this solution please. In particular, I was unsure about the contact forces between the large block and the block accelerating vertically.
you haven't mentioned if friction exists and if yes at which all contact surfaces?...
according to your diagram, friction acts on m2, then due to Newton's Third Law equal in magnitude but opposite in direction friction force must act on m1 (which you missed).
Edit: I guess, I didn't look carefully enough. Your diagram mentions that friction force exists between m1 and m2. What about other surfaces?...I assume you have drawn the diagram from the textbook/assignment, so friction doesn't exist anywhere else.
oh you i forgot that complimentary frictions must act on M1. brb will edit that into my solution.
also, for this example, you can assume that there is only friction between M1 and M2, nowhere else.
okay. balance the forces for all the three masses, you'll arrive at the answer. If you face problem, post again!
I added the force of friction on M1. (to the right)
My final answer makes sense to me in my mind but I am not sure if there is some kind of mistake or something that I am missing.
(am I correct to say that Nm3which acts on block M1 is m3a2?)
shizaep said:
I added the force of friction on M1. (to the right)(am I correct to say that Nm3which acts on block M1 is m3a2?)
Check your FBD again, I notice that their is a problem with direction of friction mentioned for block m2. Since m3 is accelerating upwards that means m2 should accelerate towards the left wrt to block m1. That means friction should act towards right on block m2 or left on m1.
yes, you are correct about that because normal force on m3 accelerates it towards right along with m1, so both have same horizontal acceleration
if you do the corrections to your FBD, you'll notice that block m2 has all the horizontal forces toward right but it accelerates towards left with respect to m1. you'll have to find relation between relative acceleration of "m2 with respect to the block m1" and "m2 with respect to ground"
I mention to make sure that it is clear, every block has a different net (vector) acceleration but it is all correlated.
P.S. :
##a_{m2}## is acceleration of m2 with respect to ground
##a_{1}## is acceleration of m1 with respect to ground
##a_{2}=1 m/s^2## is acceleration of m2 with respect to the block m1
##a_{m2}= a_{1}-a_{2}## ...minus sign means towards the left
$$a_{m1}= a_{1}$$
$$a_{m3x}= a_{1}$$
$$a_{m3y}= a_{2}$$
