Calculating Maximum Height and Final Velocity: 2 Energy Problems on a Slope
The discussion focuses on two energy problems involving an ice cube on a slope and a cannonball launch. For the ice cube, the maximum height reached after being released from a compressed spring was calculated to be 0.255 meters, which is confirmed as correct. In the second problem, the speed of the cannonball striking the ground was found to be 81.216 m/s, also deemed accurate. A clarification was made regarding the unit of the spring constant, which should be N/m instead of Nm. Both solutions provided by the user were validated as correct.
rain_ex
A 50g ice cube has no friction. It compresses a string with the constant 25 N*m a total of 10 cm. Find the max height reached by the ice cube before it starts sliding back down the slope, after it is released from the spring.
Known:
m = 50g (.05kg)
k = 25 Nm
x = 10cm (.1m)
E0 = E <- general
Us0 = Ug <- expanded
1/2kx2 = mgh <- final equation
I ended up with 0.255m. Is this correct? I solved for the variable "h".
A cannon angled 30 degrees above the horizontal launches a cannanball at 80 m/s. if the cannon is 10 m above the ground with what speed does the cannon ball strike the ground?
E0 = E <- general
Ug0 + K0 = K <- expanded
mgh+1/2mv02 = 1/2mv2 <-final equation
I ended up with 81.216 m/s. I solved for the variable "v".
Please check my solutions for me! Thank you!
Your solution is correct, but the unit of the spring constant k is N/m instead of Nm.
ehild
Thank you.
I'm assuming that the 2nd question's solution was correct too?
Yes, both solutions are correct.
ehild
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
