Capacitor and Resistance in a Series Circuit: Effects on Ammeter Reading?
In a series circuit with a battery, resistor, capacitor, and ammeter, closing the switch initiates the charging of the capacitor. As the capacitor charges, its resistance effectively increases, leading to a gradual decrease in the ammeter reading. The current diminishes until the voltage across the capacitor matches the source voltage. This behavior illustrates the relationship between capacitance, resistance, and current in a circuit. Understanding this dynamic is crucial for analyzing series circuits effectively.
Peter G.
There is a series circuit with a battery, resistor, capacitor and ammeter and a switch.
The question asks me what will happen to the ammeter reading when the switch is closed and why:
Well, I know that a capacitor charges up. What I am thinking is that as it charges up, it's resistance increases and therefore, the ammeter reading gradually decreases. Is that correct?
As the capacitor charges the potential in the capacitor increases until it matches that of the source. You are quite right in saying that the current gradually decreaes.
Ok, cool! Thanks a lot Kurdt. :smile:
