Where Is the Center of Mass for Three Aligned Meter Sticks?
To find the center of mass for three uniform meter sticks, the first step is to identify their positions: stick 1 is vertical along the y-axis, while sticks 2 and 3 are horizontal along the x-axis. Each stick has uniform mass, so the center of mass for each stick is at its midpoint. The overall center of mass can be calculated using the formula for weighted averages, taking into account the mass and position of each stick. The key challenge is correctly applying the formula to account for the distribution of the sticks in both the x and y dimensions.
diva8789
Three uniform meter sticks, each of mass m, are placed on the floor as follows: stick 1 lies along the y-axis from y = 0.500 m to y = 1.50 m, stick 2 lies along the x-axis from x = 0.110 m to x = 1.11 m, stick 3 lies along the x-axis from x = 1.34 m to x = 2.34 m. Calculate the location of the center of mass of the meter sticks. Enter the x value first and then the y value.
m1*y1+m2*y2.../m1+m2...
this is the problem that i have to figure out. i know the equation for the center of gravity as being basically (m1y1+m2y2...)/m1+m2+... but since these are meter sticks and they all have the same weight yet take up more than one point on the system, i don't know where to go from here...can someone please help me?
They are uniform sticks, so the center of mass is at the center of the stick.
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
