Does Coherent Light Waves Frequency Matter?
Coherent light waves must have a constant phase difference, which typically implies they share the same frequency. However, light waves with the same frequency can still be incoherent if they lack a consistent phase relationship. Coherence is defined by two main factors: temporal coherence, which relates to frequency spread, and spatial coherence, which pertains to the source's size. For instance, lasers often produce temporally coherent but spatially incoherent light, while distant stars can emit spatially coherent yet temporally incoherent radiation. Understanding these distinctions is crucial for applications in optics and photonics.
west
does coherent LIGHT waves with a constant phase difference MUST have the same frequency?
what about LIGHT waves with the same frequency only? will it be not coherent??
Science news on Phys.org
Coherence is a statistical measure of the field. The two major 'limits' are temporal coherence, related to frequency spread, and spatial coherence, related to the size of the source. So, it's very possible to have a highly temporally coherent, spatially incoherent source (most lasers have this type of radiation), or highly spatially coherent and tempoerally incoherent radiation (distant stars).
err so may i know what you are trying to say? i can't catch your words...maybe a direct answer to those questions would be better
TQ
Thread 'Simple math model for a Particle Image Velocimetry system'
Hello togehter, I am new to this forum and hope this post followed all the guidelines here (I tried to summarized my issue as clean as possible, two pictures are attached). I would appreciate every help: I am doing research on a Particle Image Velocimetry (PIV) system. For this I want to set a simple math model for the system. I hope you can help me out. Regarding this I have 2 main Questions. 1. I am trying to find a math model which is describing what is happening in a simple Particle...
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
