Continuum Mechanics Books - help
A user is seeking recommendations for both introductory and advanced books on continuum mechanics to better understand the subject after completing a course. Suggestions include resources from the San Diego Technical Books, which has been a longstanding provider since the 90s. A specific book used in a basic-level graduate class is mentioned, noted for its valuable information despite a poor index and some skipped steps. A link to an Amazon listing for a relevant book is also provided. The discussion emphasizes the need for quality resources to enhance comprehension of continuum mechanics.
nanunath
Continuum Mechanics Books - help please
Hi all..
Im almost done with this course in the current semester .. just academically .. I really haven't ' felt ' this subject .. haven't truly understood it ..so I'm re reading it these vacations . I need a v good book .. please suggest the best books (Introductory and advanced) in your opinion ..
thanks in advance :)
Not sure if it's any good, but it's free. I linked the main page, so there are two other books listed as well.
http://www1.mengr.tamu.edu/rbowen/
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
