Cooling a Room with 8.4*10^6J/h: How Long?
  • Thread starter Thread starter Kelju Ivan
    Cooling
The discussion focuses on calculating the time required to cool a room from 30°C to 25°C using an air conditioner with a power output of 8.4*10^6 J/h in a room with a volume of 62.5 m³. The challenge arises from the influx of warmer air as the temperature decreases, complicating the calculations of the number of particles and temperature changes over time. Key equations involve the relationship between pressure, volume, and the number of particles, with the heat capacity for a diatomic gas being a critical factor. The participants express confusion regarding when to use different heat capacities (5/2 vs. 7/2) and how to apply the equations effectively. Overall, the thread highlights the complexities of thermodynamics in practical cooling scenarios.
Kelju Ivan
Air conditioner cools the air in a room with a power of 8.4*10^6J/h. Volume of the room is 62.5m^3. At first the air is at the temperature of 30C and air pressure is 1atm, which stays a constant. How long does it take to cool the room to 25C? Note that the air shrinks while cooling down and since the pressure stays constant, more air (at 30C) flows in from the outside. Treat the air as a diatomic gas.
I am overwhelmed by this exercise. Normally I could make the equation (S is the integral sign) S Pdt = S nRdT (n=pV/RT), but now more air is flowing in, all the time warming the room and making the n change. How the hell does this work?
Ok, so you know that both the temperature and number of particles change with time. The pressure and volume are both constants. So, we can right
p_{0}V_{0} = N(t)k_{b}T(t) \Rightarrow N(t) = \frac{p_{0}V_{0}}{k_{b}T(t)}
Next, we can right the power as
P = \frac{dQ}{dt} = C_{V}\frac{dT}{dt}
It says that you have a diatomic gas. We know that the heat capacity of a diatomic gas is
C_{V} = \frac{5}{2}Nk_{b}
Substituting for the heat capacity and the number of particles,
P = \frac{5p_{0}V_{0}}{2k_{b}T(t)}\frac{dT}{dt}
Thus,
P\Delta t = \frac{5p_{0}V_{0}}{2k_{b}} ln \frac{T_{final}}{T_{initial}}
That differs a bit from the answer we were shown, but I guess it does just the same thing, you just used Boltzman's constant instead of R.
In our version we had C_p=\frac{7}{2}R. I'm not really sure when I should use 5/2 and when 7/2, since both are valid for C_p.
t=Q/P where
Q=nC_p\Delta T and n=\frac{pV}{RT}
