bhobba
Mentor
- 10,923
- 3,799
Rive said:?
As far as I know usually that works the other way around. With rapid tests, false negative is far more frequent than false positive. So if the rapid is positive it is accepted as positive: if it's negative, you may better to do a PCR.
I think you are right. But if you are negative and then get the test, it will not solve the issue it was introduced to address. Namely, the lines to get the PCR test was becoming so long as to be unworkable. If you test positive, they want to make sure you are, so the protocol for being Covid positive is required. That is under strain as well.
It is getting terrible in Brisbane. Things are moving fast. I will do a separate post about that. I think at the moment the PCR or rapid test is accepted as equally valid because the testing places are currently doing both.
Thanks
Bill
