How Do You Calculate the Current in Each Wire When a Charge Moves Between Them?
  • Thread starter Thread starter yankeekd25
    Current Wires
To calculate the current in each wire when a charge moves between them, use the equations for magnetic force and magnetic field. The magnetic field at the charge's location is the difference between the fields produced by each wire, given by B = B1 - B2. B1 and B2 are calculated using the formula B = μ0 I / (2πr), where r is the distance from the charge to each wire. The net force acting on the charge can be used to find the magnetic field, which then allows for the determination of the current in each wire. This approach effectively combines the forces and magnetic fields from both wires to solve for the unknown currents.
yankeekd25
Two infinitely long wires are separated by a distance of d = 1.4 meters. Both have current running in the positive y direction. A charge of q = +2.7 micro-Coulombs is moving in the positive y direction at v = 3.1 E 6 m/s a distance of r = 0.22 meters from the wire on the left as shown in the diagram. The net force from both wires on the charge is in the x direction with a magnitude of 53 E -6 Newtons. What is the current in each wire in amps?
Two vertical wires. A charge q is .22 meters from the left wire. The Velocity vector is in the positive y direction, and the Fb vector is in the negative x direction, perpendicular to the velocity vector. The second vertical wire is 1.4 meters away from the first.
Fb= qvb sin theta
B= u0 I / 2 pi r
I know these two equations must be used, but I'm not sure what to do with both wires. Do I need to apply the charge to each of the wires and do something with that?
First, do I find B by doing B= Fb/ qv sin 90. Is this correct so far?
Thanks in advance.
Since the currents in the wires are in the same direction, magnetic field at any point between the two wires is the difference of the fields due to each wire.
You have written the expression for the net field B. Now find B1 and B2 at the given point.
Using B = B1 - B2, solve for the current.
Does B1 = u0 I / 2 pi r, where r is the distance from the point to wire 1, and B2 is the same, but with r= the distance from the charge to the second wire?
Yes.
rl.bhat said:
Yes.
Thank you very much!
