What is the speed of a cylinder rolling down a hill?
A cylinder rolling down a hill converts potential energy into kinetic energy, but not all the energy goes into translational motion due to its rotational motion. The correct speed at the bottom of the hill is v=√(gh), accounting for both translational and rotational kinetic energy. The misunderstanding arises from neglecting the moment of inertia, which requires some energy for the cylinder to roll. The forces acting on the cylinder are gravity and normal force, but friction is also essential for rolling without slipping. Understanding these concepts clarifies the energy distribution during the cylinder's descent.
zeralda21
A cylinder rolls without slipping down a hill. It is released from height h. What is its speed when it come down? The cylinder mass may be completely concentrated on the radius R, which is the radius of the cylinder.
http://i.imgur.com/Ge3x1nu.png
The answer is supposed to be v=√(gh) but my calculations give;
At the top the potential energy is E=mgh and at the end(h=0) all energy has become kinetic energy since no friction/air drag is acting. Thus mgh=(1/2)mv^2 <--->v=√(2gh). Why is this wrong??
The cylinder is not a point-mass - some of the kinetic energy is required to have it rolling.
I am trying but I am not following. The only acting force is the downward gravitational force mg and normal force from the ground. So if energy isn't the same at the top and bottom, where has it gone.
I also don't understand that kinetic energy is required to have it rolling. The kinetic energy at the top is zero and keeps increasing as h decreases(same rate inversely right?).
Garvity and Normal the only acting forces, then what makes the cyllinder roll?
HINT: There is one more force that you are missing, draw the diagram and you will get it!
Consider the moment of inertia of the cylinder
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
