Dependent current source, find Vo
The discussion focuses on calculating the voltage V0 in a circuit with a constant current source and various resistors. Initial attempts to simplify resistors in series were corrected, emphasizing the need to account for separate current paths. The participants clarified that the 6k and 12k resistors can be treated as parallel, leading to further simplifications. After applying current division, the correct current through the right branch was determined to be 6 mA. Ultimately, V0 was calculated to be 36V using the formula V = IR.
Color_of_Cyan
http://imageshack.us/a/img26/4592/homeworkprintprob.jpg Find the voltage V0 in the network.
V = IR
Voltage Division:
(Voltage across series resistor) = [(resistance) / total series resistance)](total input V)
Current Division (for 2 parallel resistors):
(current across parallel resistor) = [(other resistor) / (sum of parallel resistors)](total incoming current)]
I can simplify the 1k and 3k resistors to 4k no matter what.
I'm not sure if I can simplify the 6k and 12k on the bottom as parallel though, but they will be 4k.
4k + 4k + 2k in series becomes 10k, assuming you can do that with the current source.
Then 10k + 6k makes
R total = 16k ohm, and then I tot = 24 mA
V = IR means Vtot = 384V.
Then voltage division would make
V0 = [ (6k)/(6k+10k) ](384V) = 144V
would this be correct?
Yes, okay so far.
Nope. Can't do that. There are separate paths with separate currents; there's a loop to the left of the current source and a loop to the right of the current source. The current will be different in the two loops. You might think about using the current division rule to see how much of the 24mA from the source flows in each loop...
Why don't you draw a simpler schematic?
You said the 12 and 6 make 4. The 3 and 1 make 4. The 2 and 6 make 8. So draw it with those 3 resistances and see what you can make of it.
BTW, it's not a dependent current source, it's a constant current source.
What others have said. OK so far.
If you redraw the circuit at this point you should see that a further simplification can be made.
Should be possible to treat it as a current divider at that point.
I got confused and thought you could simplify the resistors in series like that since it was a constant current source, heh. Never mind then. 384V seemed way too high too.
So then: :
http://img835.imageshack.us/img835/7570/homeworkprintprobedit.jpg and then doing current division:
Current through right branch = (4k/16k)(24 mA) = 6 mA
and then V knot is just V = IR, since current is the same through parallel elements
V knot = (6 mA)(6 kΩ) = 36VThanks.
That's what I make it.
