Distintion Maths Challenge
  • Thread starter aek
  • Tags
    Challenge
In summary, to find the coordinates of the point where the line y=ax+7 cuts AB (extended), we can equate the equations of the two lines and solve for x and y in terms of a. To divide AB internally in the ratio of 1:3, we can use the relationship between the x coordinates of the points to find the x coordinate of P and then substitute it into the expression for a.
aek
82
Distinction Maths Challenge
the line 2x + 3y-8=0 cuts the x and y-axis at A and B respectively. The line y=ax+7 is called l. Find
a). in terms of a, the coordinates of the point where l cuts AB (extended).
b). the value of a if l is to divide AB internally in the ratio of 1:3.
please i need your help,
thanks in advance.
If I cuts AB then the point of intersection (x,y) is a solution to the equations of both lines. So just equate the two and get the expression for x and y in terms of a.
[tex]2x + 3(ax + 7) - 8 = 0[/tex] so:
[tex]x = -13/(3a + 2)[/tex]
Do the same thing for y.
A and B are the respective intersections of lines x=0 and y=0 with the line 2x + 3y-8=0. The points (0,A) (B,0) and (0,0) form a triangle with lengths A0B. Find A and B.
If I divides AB at P in a ratio of 1:3 (ie PB/AP = 3) what is the ratio of the x coordinate at P to the x coordinate at B? (draw a vertical line from P to the x-axis (intersecting at x') and compare triangles A0B to Px'B). That will give you the x coordinate of P.
Just substitute the x coordinate of P into the expression for a from 1. to find a.
AM
a) To find the coordinates of the point where l cuts AB (extended), we can substitute the equations of the two lines into each other. This will give us a system of equations that we can solve to find the coordinates of the point.
Substituting the equation of line l into the equation of line AB, we get:
2x + 3(ax+7)-8=0
Simplifying, we get:
2x + 3ax + 21 - 8 = 0
Combining like terms, we get:
(2+3a)x + 13 = 0
To solve for x, we can equate the coefficients of x to 0:
2+3a = 0
Solving for a, we get:
a = -2/3
Now, substituting this value of a back into either of the original equations, we can solve for x and y. Let's use the equation of line AB:
2x + 3y - 8 = 0
Substituting a = -2/3, we get:
2x + 3y - 8 = 0
2x + 3(-2/3)x - 8 = 0
2x - 2x - 8 = 0
0 = 8
This is a contradiction, which means that the lines are parallel and do not intersect. Therefore, there is no point where l cuts AB (extended).
b) To divide AB internally in the ratio of 1:3, we need to find the point on AB that is 1/4 of the distance from A to B. Let's call this point P.
To find the coordinates of P, we can use the formula for finding the coordinates of a point that divides a line segment in a given ratio.
The x-coordinate of P is given by the formula:
xP = (x1 + kx2)/(1+k)
Where x1 and x2 are the x-coordinates of A and B respectively, and k is the ratio in which the line is divided (in this case, 1/4).
Substituting the values, we get:
xP = (0 + 1/4(8))/(1+1/4)
xP = 2
Similarly, the y-coordinate of P is given by the formula
What is the "Distinction Maths Challenge"?
The "Distinction Maths Challenge" is an annual mathematics competition for high school students. It aims to challenge and inspire students to excel in math and develop their problem-solving skills.
Who can participate in the "Distinction Maths Challenge"?
The "Distinction Maths Challenge" is open to all high school students, typically from grades 9-12. Both individuals and teams can participate.
How is the "Distinction Maths Challenge" structured?
The "Distinction Maths Challenge" consists of a series of challenging math problems that students must solve within a given time frame. The questions cover a range of topics, including algebra, geometry, trigonometry, and calculus.
What are the benefits of participating in the "Distinction Maths Challenge"?
Participating in the "Distinction Maths Challenge" can help students develop critical thinking, problem-solving, and time management skills. It also provides an opportunity for students to showcase their math abilities and potentially win prizes or awards.
How can I prepare for the "Distinction Maths Challenge"?
To prepare for the "Distinction Maths Challenge," students can practice solving math problems from previous years' competitions. They can also review fundamental math concepts and practice their problem-solving techniques.
  • Math Proof Training and Practice
9K
10K
15K
