Does Beer-Lambert's law calculate the absorbance of a solute
The discussion centers on the application of Beer-Lambert's law in analyzing the absorption characteristics of solutes in blood. The molar extinction coefficient is specific to the solvent at a given concentration and wavelength, and for accurate concentration calculations of a solute, one must select a wavelength that is primarily absorbed by that solute. The complexity arises when considering that absorbance is a cumulative measure of all substances present, making it challenging to define a "molar extinction coefficient" for a mixture with varying compositions. Accurate results in measuring the absorption of a solute in blood require careful sample preparation, which may involve extracting the solute or modifying the sample to eliminate interfering substances. Blood presents particular challenges due to its complex mixture, necessitating tailored procedures for effective analysis.
Irfan Nafi
I'm currently doing a project that involves beer-lambert's law and am confused as to what it actually calculates. So far, my intuition goes as follows: The molar extinction coefficient is for the solvent at a specific concentration and wavelength. In this case, it is blood. And if you have to calculate the concentration of a solute, then you have to get a wavelength that is primarily absorbed by the solute. So the question is: if I have another wavelength that primarily absorbs something in the blood, then will the molar extinction coefficient be that of blood at that wavelength?
Chemistry news on Phys.org
Very roughly speaking measured absorbance is a sum of individual absorbances of all substances present. Doesn't make much sense to speak of "molar extinction coefficient" of a mixture with variable composition.
This is actually much more complicated, as it works reasonably well only for diluted solutions, but that's the general idea.
Likes Irfan Nafi
How would I get the most accurate results?
Most accurate results of what?
Likes Irfan Nafi
Sorry for not clarifying - the absorption of the solute in the blood. I'm using an LED and a photodiode for detection. Would I just use the molar extinction coefficient of the blood?
No, you need to prepare the sample so that you measure absorbance of the solute you are interested in. There are no simple rules here, sample preparation is not something where a single recipe works for everything. Sometimes you need to extract the solute, sometimes you need to add things that will destroy/precipitate other interfering substances. The more complicated the solution, the more elaborate the procedures are. Blood is quite a difficult mixture to analyze.
Likes jim mcnamara, HAYAO, symbolipoint and 1 other person
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
