SpIIIdD
- 2
Hello everyone, I'm new here.
I'll just post my question- hopefully someone can answer.
A 2.00 kg block situated on a rough incline is connected to a spring of negligible mass having a spring constant of 100 n/m. The pulley is frictionless. The block is released from rest when the spring is un-stretched. The block moves 20 cm down th incline before coming to rest. Find the coefficient of friction between the block and incline.
m= 2 kg
d (delta x)= 20 cm (or 0.2 m)
k= 100 N/m
angle to the horizontal, theta= 37 deg.
coef of Fk= ?
a relevant equation, i think, for this problem is coef of Fk= Fk/Fn (normal force) but I'm not 100% sure about anything else.
So first i tried to draw the full body diagram of the forces of that are acting on the block.
The mg force points straight down, the kinetic frictional force should point diagonally to the left and the normal force points diagonally upward (parallel to the surface of contact where the block rests).
However, I'm not exactly sure what the force going diagonally to the right and downward- opposite to the force of kinetic friciton going opposite the direction at movement. I thought maybe that the force would be the force exerted by the string, Fx, but when i conceptually try to calculate it (with the formula Fx= -kx or kx ) i seem to obtain 0 (since the spring is being uncompressed and therefore returning to equilibrium, k should equal 0? (and multiply then by x- 0.2- and the answer is zero or have i got it wrong)?
I'm just generally confused as to how to continue with this ques and am wondering maybe there's something worng with my reasoning. I know that what I've done should be folowed up by solving a system of equations to get the final value but I'm not sure how to go about doing it.
Help?
m= 2 kg
k= 100 N/m
coef of Fk= ?
Help?
