Easy yes or no answer sine law question.
  • Thread starter Thread starter ryan8642
    Law Sine
The discussion revolves around the application of the sine law in a specific calculation involving the inverse sine function. It highlights the importance of recognizing angle restrictions, particularly that the arcsin function yields results only between -90 and +90 degrees. The calculation presented involves using the sine of 120 degrees, which is equivalent to the sine of 60 degrees, raising concerns about angles exceeding 90 degrees in triangles. Participants emphasize the need to consider these restrictions when solving triangle problems. Understanding these limitations is crucial for accurate results in trigonometric calculations.
ryan8642
Is it ok to use sine law for this :
A=sIN^-1(40SIN120/65.8)
im not sure if this applies to the sin law angle restriction where the angle can't be over ??degrees?
sin(120 deg.) = sin(60 deg.). The sin-1 (or arcsin) function on a calculator will give you a value between -90 degrees and +90 degrees, so for some triangles with angles larger than 90 deg., you need to take this into account.
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
